Question about Karcher 1750 psi Electric Pressure Washer
I started working with the Karcher KB4040 pressure washer and all was well for 1-2mins, then it sputered a bit and all power died. All hoses were still attached properly, it hadn't blown a fuse in my house and the fuse in the plug of the washer is working fine.When I switch it on I get nothing. Do you think the motor has packed in? I borrowed the machine from my neighbour who's away on holiday, so don't know much about age of the machine. Any advice much appreciated.
  • mrobb_montre Jul 22, 2009
    Thank you so much nettiser. I went back to the machine, set it all up again, ensured all hoses were attached properly and it worked perfectly.
    I'd never heard of the protection mode but I guess that's what happened.
    Many thanks.
    Brigadier General:
  • 4,090 Answers
If the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
Posted on Jul 22, 2009
My pressure washer motor keeps cutting in and then stops, when i
am using the machine, it only happens when i stop using the pressure washer . Before the motor stopped immediatly when i stopped using the washer..
The water is swiched on and there is plenty of pressure.
To over come the problem i switch off the machine on the switch.
Other than this the machine works ok
Posted on Mar 03, 2010
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 | Garden
Karcher KB4040 pulsing when trigger closed and has lost about 50% of its power
Just google " stripping down Karcher KB4040" A YOU TUBE CLIP will show you hiw to fix it and what tools you need
Jun 05, 2012 | Garden
I have a pressure washer that sputer when i pull the trigger. The moter sounds fine but i have pressure then nothing and i have pressure. Thank you Stu
how do i unclog the end of my pressure sprayer it works on low pressure but when i put it on high pressure nothing comes no water comes out.
May 03, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
What's wrong when you only get full pressure for the first few seconds and then it stops and won't spray fully anymore?
Air pockets in the supply hose or the supply is feeding the power washer too slowly.
These things can really put out quite a bit of water, so make sure you've got a good supply going to it. No kinks in the hose, spigot opened all the way, etc.
If the problem is air pockets, make sure you're running the feed hose long enough to get a good flow of water before hooking up to and starting the power washer.
Jun 01, 2010 | Karcher 2500 PSI Pressure Washer
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Where does small spring fit in gun of karcher pressure washer kb4040
Most Karcher guns I have worked on have had a spring behind valve between hose pipe inside gun.
Apr 21, 2009 | Garden
Karcher 1750 psi Electric Pressure Washer Logo
1,322 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
