Question about Epson Stylus Pro 9800 InkJet Printer
Paper loading error
I keep getting (paper setting error load roll paper)coming up even though paper is correctly loaded
  • 41 Answers
Hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Posted on Jul 22, 2009
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
Dec 20, 2012 | Lexmark E260dn Laser Printer
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
My printer (Epson R800) keeps on giving me the error 'Media not loaded correctly'. Even before it's even tried grabbing the paper, it starts blinking red on the paper/trash button. I've never had this
Please make sure that the paper that you are using is included under the printer's paper compatibility list.
Make sure that you are selecting the correct paper type on printer settings.
Trash and re-install the drivers.
Apr 29, 2009 | Epson Stylus Photo® R800 InkJet Printer
9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Error Code E0200D
I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
Feb 19, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
No Paper Recognised
What paper type is set in the driver? ie plain, letter, A4, cardstock?? Also which tray source is accepted. Might try re-setting driver settings to defualt.
Aug 29, 2007 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus Pro 9800 InkJet Printer Logo
436 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
