Question about Maytag MGD9700S Gas Dryer
I bought two gas dryers(MGD9700SB0) for homes we were constructing.They were installed in July 2008 and I've had problems with both. One dryer is going on its 3rd service call in less than one year. It just won't start up yet the lights go on. The serviceman now says I need a new control panel. I am so very disappointed with Maytag. I'm ready report this to the Better Business Bureau or other gov't. agency unless I get this problem fixed as soon as possible.
  • vivordan Jul 22, 2009
    I will advise Maytag first. While the problem itself is not fixed, I appreciate the responsiveness.
  • Maytag Master
  • 19,396 Answers
Good Morning.
I am sorry to hear about your problems.
Often a large appliance fault may be difficult to fix, and the technician may need more than one service before fixing the problem.
Maytag appliances are covered under warranty for the first two years, and you should be entitled to free parts and service until the problem is fixed.
What the technician did was reading error codes, and in your case a faulty timer board may have returned the wron fault code, leading the technician to replace the wrong part.
If you get charged for the service , or if you want a different technician you will better contact Maytag first, rather than contacting a Governative customer protection agency. Maytag can be contacted following indications on this page: Maytag Contact Us.
Best regards.
Posted on Jul 22, 2009
Can this samsung gas dryer convert in electric dryer too
While it is possible to convert your dryer from electric to gas or vice versa, you will find the cost to be excessive and not worth consideration. A gas dryer will have3 a gas burner and ignitor circuit system while the electric dryer will have a heating element and controls. This is NOT a practical conversion nor would it be cost effective. If you need a gas dryer for your new home, purchase a new dryer or save a few $$$ and check your local Craig's List for a good deal on a used gas dryer. Just beware that you don't buy someone elses problem. There are legitimate sales caused by moving or upgrading appliances that will allow you to find a great bargain. Drop any notion of converting your dryer!
Apr 01, 2014 | Samsung DV419AE Dryer
Tip
Choosing a dryer.Gas or Electric
A gas dryer saves electricity cost, but requires an installed gas line to the home and special installation. If gas is available for a dryer, the outlay for a gas dryer model may be a good option if your dryer usage is high. An electric dryer costs less, but requires installation and energy costs for a dryer varies with usage. Both types of dryers require proper venting to the outside. Always follow the dryer manufacturer's installation recommendations.
on Aug 17, 2010 | Refrigerators
We've got a noisy Maytag gas dryer and it has been suggested it needs brake shoes on the front and rollers on the back of the drum. Is anyone near enough to Oberon to assist us please?
To access the front you remove 2 screws at the base of the front and remove the front panel, newer models you pop the top first. Not all maytags are exactly the same. The front of the drum rides on plastic glides and the rear of the dryer rides on rollers. I made a few maytag dryer home videos HERE
Jul 23, 2012 | Maytag Dryers
Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag Neptune MGD9700A dryer. It is LP.
Most times that is a sign that the gas coils are weaking. I am having a little trouble with your model number so I' not sure what your part numbers will be. Get with me later if you should find the model numer to be different. On Maytag they are inside the door. I am not saying that you are wrong but that I could find only this series MGD9700SB0 One coil should be part number 694540 Coil, 60 Hz. (2 Terminal) (Main) and the other part number 694539 Coil, 60 Hz. (Split) (3 Terminal) (Pilot Position) You can find these valve in a larger photo discription on this page=> Seabreeze Appliance Parts just click on photo to enlarge.
This is the 694540 and you can find Here=> 694540
daaffda.jpg And here is the part 694539 Gas Valve
Click Here=> 694539
b7ef152.jpg If you have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 20, 2010 | Maytag Neptune MDG9700A Gas Dryer
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
Kenmore electric dryer - plug too big for outlet
you need a 240 outlet box installed the only dryers that run on 120 are gas dryers you purchased an electric dryer and it needs 240 volts. you need to talk to your landlord and ask him or her to have a 240 outlet installed for you
Dec 29, 2008 | Home Maid CD250UT Dryer
Bought cherry lg tromm dryer, bf ruined the gas line hook up (tried to fit the wrong size hose) can this be fixed and what can we do?
if the threads are ruined on the dryer unit itself, id reccomned calling in an lg authorized repairman. if it has to do with gas line installation go with a liscenced plumber.. why mess with GAS in home.
Mar 04, 2008 | Dryers
Maytag MGD9700S Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
