Can I make an ethernet connection to my Panasonic by wireless, so that I don't have a cable crossing 2 rooms?
  • 82 Answers
You need a WAP (Wireless Access Point)
Posted on Jul 25, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
My Advent Roma 2000 says network adapter not connected. How do I connect it?
First, you need to have something to connect it to, such as a cable-modem, an ADSL-modem, or a router.
Second, you need a "straight-through" Ethernet cable, not a "cross-over" Ethernet cable.
It's an 8-wire cable -- do not use a 2-wire or 4-wire telephone-cable.
Plug one end of the cable into the 'LAN' port on the other device, and the other end into the network-port on your computer.
Apr 10, 2010 | Computers & Internet
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Is there an ethernet cable that will fit into a panasonic cf28 toughbook laptop as i need this in order to get it to go wireless
If there's an ethernet socket on the computer then there's a cable to fit it.
Most computers today have ethernet as standard (the socket and cable have been standard for years).
Why do you have to use the ethernet to connect wirelessly? Normally just activating the wifi in the computer and logging into the router is all that is needed.
Jan 06, 2010 | Panasonic CF-28 (cfwwl281m) Wireless...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I make my Compaq SR1520NX wireless?
Well, you can always use the new tecnology and connect you ethernet via your power-line in your house/appartment.
http://reviews.cnet.com/adapters-nics/panasonic-hd-plc-ethernet/4505-3380_7-31940393.html
Follow that link and read about it, i link you to the panasonic test results, but there are many many more manufacteres out there.
Its verry verry easy to use, its not expensive, and you wont need any separate cables.
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 16, 2008 | HP Compaq Presario SR1520NX (PX801AA) PC...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
