Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What is the washing technique in whirlpool washing machine
  • 5,660 Answers
Are you referring to the Whirlpool Cabrio WTW6600S Series of washers?
They don't use an agitator like a conventional washer. They have a movable wash plate located in the bottom.
http://products.howstuffworks.com/whirlpool-cabrio-top-load-washer-wtw6600s-review.htm
Posted on Jul 24, 2009
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Whirlpool Washing Machines
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Whirlpool Duet washer showing code F11?
The F11 code is a loss of communication between the CCU circuit board and the MCU circuit board. (CCU Central Control Unit, MCU Motor Control Unit) The most probable cause is bad solder joints on the CCU circuit board (also known as cold solder joints). This condition is also noted for causing a FdL code (door lock) The cure is to remove the CCU (inside machine, top, back, plastic case) remove the plastic case then the circuit board, it's easier that way. Then touch-up the large solder joints holding the spade connectors and the relays (5 of them). If you're not up on soldering techniques, you could take the CCU and this response to a good appliance repair shop and they should be able to help you out. Good luck.
Apr 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine doesnt finish the wash. When it is almost done it starts to beep and flashes the letter F. This happens before the drain/spin cycle. Help!
This problem is most often the CCU circuit board (inside, top, back, plastic case) there are bad solder joints on the circuit board where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the board. Often times the vibration of the machine will make or break one of these connections causing the machine to stop at various times. The cure is to remove the CCU case then the circuit board and touch-up those solder joints I mentioned. If your not up on soldering techniques you can remove the CCU case and circuit board and take them, along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Feb 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE washing machine motor does not WPRE6100G1WT are
What problems are you having with this machine?
Jan 21, 2011 | GE Washing Machines
Door seal leeks. The rubber around the door leeks
Sounds like your bellows is worn and has begun to leak. Here's the way to change it...
The bellows will have a retaining wire on both the front panel and plastic tub interfaces. You need to remove the front panel wire first. Simply pull the lip forward until you can see the wire. Use a pliers or screwdriver to remove it. Peel the bellows off of the front panel and you can see the attachment to the tub. Same removal technique.
Be very careful when installing the new bellows to be sure it is seated fully and correctly all the way around the tub. Reinstall the retaining wire. Same installation technique for the front panel.
Good luck.
Jan 20, 2011 | Whirlpool AWM6120 Front Load Washer
I was cleaning the water seal and the retainer spring came off. How do I put this back on. Does it go over or under the water seal.
It goes over the seal, in the lip of it, spring on the bottom. The best technique is to put one half on and hold it in place using your forearm and slowly work it all the way around.
Please rate me if my solution was helpful.
Thanks, Repairman45.
Dec 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where is the filter?
The filter is under the washer door.You take off the bottom panel under the door and you will see this white knob that screws off.Just make sure the washer has
drained if not you will have a flood.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
721 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
