Advent 5431 Wi-Fi only good for 10 metres from Router.
Laptop brought 2nd hand. Still under warranty. Store says to uninstall WiFi driver. Done this and problem still exists...
If I use laptop by router it is five bar strength. lifting laptop away from router that drops to four bar strength. If i take it away to another room (10metres) it goes to 3 bars straight away and then drops out...
Store advises a ''full destructive recovery'' and then re-load from inbuilt restore..... It does not have recovery discs?.
Not tempted by that at this stage as it didn't work when re-loading Wi-Fi drivers before?.
Can anyone offer a constructive idea on how to get better Wi_Fi out of this Advent 5431?.
Thanking Everyone out there who takes time to help people like me who have no idea!!!.
Paul.
    President:
  • 1,383 Answers
You have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 22, 2009
How do I get the wi-fi- working on my laptop after installing windows 10?
try typing wifi or wlan in the search box or windows wireless, that may throw up results for you to trawl through
Oct 26, 2015 | HP Pavillion G6 1d72nr I3-2350m 15.6"...
My Dell inspiron won't recognize wifi
Hi Mike,
There is a possibility that the Wi-Fi may not have been enabled so please let me know the system model so that I can let you know what needs to be done. You may also send me the system service tag so that if Wi-Fi is already enabled then I can check and provide the right Wi-Fi driver.
Thanks & Regards,
Kiran K
#IworkforDell
Dec 26, 2014 | Dell Inspiron Computers & Internet
When i turn on my wifi my laptop starts to hang what can i do?
HI
it sounds like there are two or three possible solutions.
1. Enter the bios after reboot laptop, and disable the soundcard. If this works then there is an IRQ conflict. You will need to reinstall the soundcard with the Wi-Fi switched on to resolve this.
2. Some firewalls are unpredictable. disable you firewall and browse to safe sites. see if that helps. Your Broadband router should protect you machine. !!! don't turn off you anti virus!!!
3. Your driver or your WIFI card are faulty. Reinstall the driver for your Wi-fi card from your laptop.
If none of the above work I would say replace your Wi-fi card.
Jul 30, 2013 | Sony VAIO VPC-SA33GX/BI Laptop
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
Can not detect wireless network on wifi enabled
Make sure on laptop wi fi switch is turn on.
Uninstall wi fi network adapter driver then reinstall.
Right click on my network places and click on property then right click on wi fi adapter and enable it and click on view available wi fi networks .
If you still not detect signal of router then You hav to reset router.
For thjat press RESET button for 10 seconds it is in back panel of router.Then it defaults.
then connect router to computer with ethernet cable then you can access it with below link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Then set WAN settings as your isp.
GO to wireless settings and enable it .
If you want to secure enable WEP security and add wep code.
Enable DHCP.
Then save and restart router then check.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | HP Compaq nx9020 Notebook
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
I have an Acer aspire 5610z Just acquired a Verizon MIFI2200 53CF Secure Ability to network 5 wireless computers Was able to configure below not problem IBM T60 Compaq Presario Not the case with...
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Aug 03, 2009 | Acer Computers & Internet
My laptop has Wi FI My mobile also has wifi can
No. Laptop and Mobiles are passive WiFi receivers. You will need a WiFi router which when connected to internet will create a WiFi zone around it. You can no connect your laptop and mobile to this router.
Feb 26, 2009 | Dell Inspiron 1501 Notebook
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
