Question about MSI K9VGM-V Motherboard
No audio after installing 2*2GB
I also found out that installing 4Gb of ram shut outs the soundcard.
Tried everything, including deleting most of the sounddriver but nothing happened.
Is there already a solution for this problem.
Corneliu
  • hamcoco Jul 22, 2009
    Thanks,
    It is on the other hand odd that the board accepts the 4Gb and works with it. I found a significant improvement when I placed the 4Gb.
    So my choice now will be sound or speed.
    Corneliu
    Brigadier General:
  • 7,191 Answers
Your motherboard supports maximum 2GB RAM. So, the problem is due to the 4GB RAM.
Check your motherboard details here:
http://www.msi.com/index.php?func=prodmbspec&maincat_no=1&cat2_no=&cat3_no=&prod_no=260
Hope this solves the problem. Thanks.
Posted on Jul 22, 2009
Sound doesnt come out from guitar link UCG102
what you need to do is install the asio4all driver then select file, adio midi settings and where it says behringer audio codec click the arrow and select asio4all then click the configure button and in the wdm list you must activate all the items under audio codec and the audio speaker under High Definition audio device this will allow it to work through the speakers, or just leave it how it is and plug in a set of headphones. make note though that your speakers will play nothing else but the guitar sound. all other music internet sounds, the lot will no longer work as your ucg102 is high jacking your sound card to produce the sound from your guitar. hope this helps.
May 27, 2009 | Behringer (UCG102) Sound Card
My printer has a job waiting that I can't cancel. I've tried everything including turning off the printer to erase the memory, and completely restarting my computer. Nothing will delete this print job
your job is stuck in the printer que, to cancel this go to control panel, open printer and other, right click on the printer icon, delete the job in que (are you sure you want to delete, yes)..........and you are done
May 10, 2009 | Office Equipment & Supplies
Ive deleted sound on my computer. wat do i need to do? no sound found
Hi peewee,
I'm not entirely sure what you mean by deleted sound.  I'll run some questions by you to clarify.
Have you: -checked to see that all of your speaker cables are plugged in correctly and that your speakers are functioning properly -have you checked to see that everything is turned on and has power running to it -are you running XP/Vista/Linux/OSx? -have you recently installed any audio codecs or soundcard drivers? -if you go to your startbar, and look at the speaker icon in the bottom right corner, right click and select open volume controls, check to see if anything is muted or has the volume down
Hope that helps.
Mar 12, 2009 | Computers & Internet
M-audio soundcard 410, problems with vista
I had a similar problem, until I turned off my WiFi. I din't want to believe it would be the problem but it sure was, sucks that I cant be online while i'm trying to record something.
Dell Studio 1737
Vista 32
4GB Memory
300 GB SATA Drive
Jan 14, 2009 | M-Audio FireWire 410 External Sound System
More ram and vdeo card
it sounds as if your MoBo is seeing the video adapter as a source of ram. if that is the case, then installing memory in units of 1Gb will cause a stick to not be seen, therefore utilized. you may want to refer to you manual for memory limits and poosible comparibility issues. they are usually quite in depth. also, make sure that they are all the same make model and speed. these issues have wreaked havoc on the prettiest of pc's.
Nov 28, 2008 | Computers & Internet
Just Tried Again
its permissions to registry or system folder.
Jul 31, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Pc starts up and shuts down repeatedly and no video
First be sure that the ram (ecc)you have purchased is compatible with your motherboard and that it will take a total of 4 gig,make sure you earth yourself out on the case before going inside the pc (static electricity can damage electronic components)check that you have not accidentally loosened any data or power cables, check cpu & fan is seated correctly and working : then
  • put back the old ram and try booting up,(if still no good),
  • put things back to the way it was before the changes,
  • make sure everything is working as before (refer to the above)
  • trying the new ram, if ok
  • change cpu
  • this will identify if it is the ram the cpu, or some other problem
it is a good idea when upgrading the pc to do one thing at a time so that it is easier to identify any problems that crop up.
let me know how you get on
good luck
Terry
Mar 23, 2008 | Computers & Internet
Cannot see 4 gb ram
Hi Ciccio8670,
If you are running 32-bit Windows, you must live with it. You will not ever see all 4GB of RAM you've paid for.
If you are running 64-bit Windows, you may have to live with it. Depending on your motherboard's chipset, your system may support memory remapping. If so, you will be able to use all 4GB of RAM.
Detailed:
Due to an architectural decision made long ago, if you have 4GB of physical RAM installed, Windows is only able to report a portion of the physical 4GB of RAM (ranges from ~2.75GB to 3.5GB depending on the devices installed, motherboard's chipset & BIOS). This behavior is due to "memory mapped IO reservations". Those reservations overlay the physical address space and mask out those physical addresses so that they cannot be used for working memory. This is independent of the OS running on the machine. Significant chunks of address space below 4GB (the highest address accessible via 32-bit) get reserved for use by system hardware: • BIOS – including ACPI and legacy video support • PCI bus including bridges etc. • PCI Express support will reserve at least 256MB, up to 768MB depending on graphics card installed memory
What this means is a typical system may see between ~256MB and 1GB of address space below 4GB reserved for hardware use that the OS cannot access. Intel chipset specs are pretty good at explaining what address ranges gets reserved by default and in some cases call out that 1.5GB is always reserved and thus inaccessible to Windows.
Feb 13, 2008 | ASUS P4P800 SE (890552603657) Motherboard
How do i delete videos off of sansa e260(4Gb)
Do this.
Go to computer
And see the removable disk.
Locate the one that its attached to
Right click
Format it
It should work.
Dec 22, 2007 | SanDisk Sansa e260 MP3 Player
Soundcard driver
looking for frontech soundcard driver
Dec 01, 2007 | Dynex DX-SC5.1 Sound Card
MSI K9VGM-V Motherboard Logo
314 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
