Question about Sanyo Microwave Ovens
I have a EM-S1565 microwave which has worked perfectly well until today. The power is on the turntable is working but it will not heat up. Do I need to take it to a repairer or is it something I can fix myself
  • Sanyo Master
  • 458 Answers
It is best to take to a repairer. Firstly Microwave can be dangerous to work on if you are not electrically experienced & secondly ther may either be a problem with the thermal cut out or the magnetron, either of which needs specialist investigation.
Posted on Jul 22, 2009
Microwave not heating. It's showing a unusual emblem
  • Open internal fuse
  • Defective control board
  • Defective door interlock
  • Failed magnetron
Apr 21, 2017 | Microwave Ovens
My under cabinet microwave is not working correctly.
The possible reasons are: 1) The high voltage transformer is broken, 2) The magnetron is broken.
For the 1st problem, no power can be applied to the turntable.
For the 2nd problem, the magnetron is broken with no microwave can be issued.
Jul 14, 2015 | GE Microwave Ovens
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
GE Spacemaker JVM1533WD turntable sometimes works, mostly doesn't
The part with the three rollers that holds your turntable needs to be replaced if you want it to turn. That plastic and those rollers get cooked over time like everything else. The microwave is designed to basically cook with the moisture in anything placed inside the microwave. Those rollers have probably become warped enough so they don't roll properly when heated and that is why they do work somewhat after a night of nonuse. You may be able to find one at a local repair shop for almost nothing. Those parts are pretty generic. Even at a garage sale or flea market. Other than buying from a local dealer you can go on the internet at www.mwoparts.com and get any part for the microwave. Good luck and God bless you.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo EM S667W 1000W 240V Microwave.
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 12, 2008 | Sanyo EM-W3000W 1000 Watts Microwave Oven
Microwave turntable does not turn
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
May 02, 2008 | Microwave Ovens
Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 18, 2007 | Microwave Ovens
Microwave Ovens Logo
66 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
