Please can you help, i have the Technika LCD42-910 and when it changes scenes or the screen is black i get a buzzing noise until either the screen comes back in colour or an advert starts or the next scene. many thanks
Hi did you find the problem? Well I had this you need to change your sound from cinema to dynamic or natural. easy
Posted on Nov 24, 2010
Hi Gill
Hope that you solved your problem with your Technika LCD42-910.
I have the same TV but have lost the user manual after moving home. Do you know where I can download a copy. peter_mcgarry1(at)msn(dot)com
Posted on Dec 12, 2009
I have a amazon fire hd 8 how can i chang the pic. on the lock screen please help
Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
  1. From Settings, tap Lock Screen, and then tap Select a lock screen scene.
  2. Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
  3. Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
Dec 27, 2016 | Amazon Tablets & eReaders
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Lcd32f 1080p
There is only one possibility of noise [high-frequency] to LCD TVs. It should be coming from its back-light inverter board. The ferrite cores of the inverter transformers at the back-light inverter board can make this noise; if there is any loose fittings. Check it.
Gopakumar Gopalan Google
Apr 22, 2014 | Bush Televison & Video
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
My TV is buzzing nonstop. What will fix this??
is it buzzing when turned off or just on and is it buzzing durning bright scenes or just buzzing bright scene change buz is an If problem . in todays set , the best thing to do is change out the signal board sometimes
it could be a transfomer laminate buzz in the case your best bet would be to hire a tv tech to take a listen
Nov 20, 2009 | Akai PTH5498 54" Rear Projection...
The screen goes blank, wii emits buzzing noise.
refrain from playing for a few days.
its what you call a black screen of death. it will keep happening until your wii stops if you dont refrain from playing for a while and obey the health/safety rules (sometimes the wiis pass becuase the health/safety rules hide the bsod) [health/safety rules: take a ten - minute break every hour.] BE CAREFUL WITH YOUR WII IT IS VERY FRAGILE IF IT GETS A BSOD!!!!!!! {fragile=easily damaged INTERNALLY}
Feb 17, 2009 | Nintendo Wii Console
Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
Dec 23, 2008 | Samsung SP-S4243 Television
Buzzing until warmed up
This is caused by a defective capacitor in the power supply board. A very detailed answer is given by stiv0. His solution is for a "no power" or "black screen" condition, but this also fixed my noise on power up. I had noise that went away, but eventually it stayed on all the time. His explanation is correct except in describing how to get the back cover off. He says to take the 3 screws off the back of the black plastic cover on the back and then "pry" up the plastic. Actually if you slide the plastic down about 3/8 inch the cover will lift out easily. I fixed mine today in about an hour.
Hope this helps.
Trent
Sep 10, 2008 | Polaroid FLM-3732 Television
Buzzing/Fizzing noise at the back of TV.
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
498 people viewed this question
Top Televison & Video Experts
Electro Med Services...
