Question about HP Photosmart C5280 Printer
Continuous PAper jam error-message!!!
I have a C5280 printer about 2-3 years now. I was printing some rice papers when I had the error message. When I shuted down the printer, the paper that was supposed to be jamed came out alone. I tried to print once again and after the first print I had the same message. Repeating the same process with the shutting down fixes the problem for just one print .At the second I have the error.
REplaced the cartriges but still having the same problem. Now I just print one copy and then I print one copy and then I print one copy etc not so helpful.I have read the other jam problems and their solutions and tried them all but I can' t find the problem. Any suggestions? THanx
    Problem Solver:
  • 12 Answers
Sounds like a small piece of the jammed paper is stuck inside on a paper path switch OR in pulling out the jam you've dislocated a switch actuator so it is not working correctly. Careful checking of the paper path components should find it. Probably a slot in one of the guides is hiding it.
Posted on Jul 22, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
Our printer jammed and now will not correctly align paper or print anything else. How can I fix this?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 30, 2010 | HP Photosmart C5280 Printer
HP Officejet 5610 All-in-One continuous paper jam,
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
