Question about Nokia Cell Phones
My n95 classic's front camera is distored it shows very very blur poor image
My cannon power shotA4000IS suddenly stop showing/focused pictures the scree show a blurred image of photo taken?
If you are convinced you did not switch the camera to manual settings, and the blur stays, please contact the nearest Canon certified service centre close to you. But before check the settings on the camera and start putting it on automatic.
Sep 11, 2014 | Cameras
Nikon s3300 lens alert showing after blurred image
hello,you have the classic quirk what is known as 'CAMERA SHAKE' you need to practice holding the camera VERY steady,do not stab at the shutter release,but just SQUEEZE the button,but without the slightest movement of your hands that are holding the camera,brace yourself on to a fence,or a wall(your back on to it) also adjust both arms to a 'V' position and place camera partly on your forehead,than lean partly on to a solid object,or nearby fence or wall with your back,keep practicing,as that is the only way for blurr free images, hope that helps, cheers.
Jul 30, 2013 | Nikon COOLPIX S3300
Viewfinder shows blurred images
First, rotate the mode selector dial to "Auto", then check to ensure that you're not in macro mode. Also make sure that your lens is clean and there are no smudge marks.
If you've done all the above, and you're still getting blurred images, this then might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot A80 Digital Camera
Logitech Quickcam Communicate Deluxe blur images showing
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Jan 20, 2009 | Logitech QuickCam Communicate Deluxe...
Blurred pictures on canon powershot S1IS
I don't know if Canon is offering out of warranty repairs in any country. You should contact Canon in your country to request a repair if it's under warranty, or ask about the fault if it's a recognised common fault
Cananda, look here:
https://orderdesk.canon.ca/RepairOnline/bookOrTrack.do?method=languageSelection&lang=en
UK, look here:
http://www.canon.co.uk/Support/Consumer_Products/services_locator/index.aspx
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 10, 2009 | Canon PowerShot S51S Digital Camera
Web cam showing blurred images
First off welcome to fixya.com.
You may try adjusting the cameras focus. Usually on the front of the camera where the lens is located it will turn left and right. Turn it one way until it gets clearer, if it gets more blurry turn the other way.
Also make sure the lens is clean by taking a soft cloth and wiping it off, some cameras have very small lenses so you may need to use a Q-tip to get the soft cloth onto the lens.
I hope that helps out, if not feel free to let us know.
Jei
Dec 11, 2008 | Logitech QuickCam Express Web Camera
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
No image -- just colors on led and photo
I found the same fault, but for me it is intermittent. I have tried all sorts of things to clear it, but the best seems to be leave it turned off for a while. I bought my Ixus 400 in Sept 03 and the fault started in Jun 07. It shows already taken pictures with no problem on review on the LED screen, but the screen blurs (with motion) and records that same blurred image.
Sep 28, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Cell Phones Logo
128 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
