Question about Dell A525 Computer Speakers
Left channel will not play - Dell A525 Computer Speakers
  • Dell Master
  • 458 Answers
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Posted on Jul 22, 2009
Technics amp to tape deck connections.
Red for Right channel (play). White for Left Channel (play). Yellow for right (Record) Black left (record). The leads should run from tape (out) play to amp in play. Same for the left channel.
Record from tape (in) to Amp (out).
Jan 29, 2014 | Audio Players & Recorders
Keeps blowing speakers on left front channel
What exactly do you mean by "middle volume settings"? Where is the volume control physically, where are the channel levels set and what is the crossover point? After the crackling appears , do you switch speakers to the right channel to see if speakers are actually damaged or if the receiver is producing the distortion?
Jan 22, 2014 | Pioneer VSX520 Receiver
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
Sound pc d3941 zennox
Yes and no. If you swap the channel leads over the fault should go to the other channel. Still the same, then not the Cassette deck.
There are several causes to one channel going. First the lead to the tape head is off or the head has gone!! Secondly a switch either on the front of the machine or the inside (when it switches to record) is faulty. Lastly an electronic fault. The good thing is that you have one good channel to play with. So as they are both the same any readings should be the same for both channels. The electronics will also buzz when touched with an insulated tool. So if it buzzers in one place in one channel it should do the same in the other in the same place.
Jun 22, 2013 | Sony TC-WE425 Dual Cassette Deck Single...
C370 faint crackling sound left channel
have you tried looking at your phono leads,turn volume down until it is low enough that you can still hear the music playing,give the phono leads a turn to see if its a loose connection.if not,try the right channel phono in the left channel to see if this fixes your problem.also you could do the same with your speaker leads and see if that solves the issue.maybe a bad connection is the cause?.it may also help to try and move your cd player away from your amplifier.it could also have been overdriven (played too loud for too long) on the night of the party,only you will know if this was the case or not.
Jan 07, 2013 | NAD C370 2-Channel Amplifier
Left channel don't work
The IC in it is fied for the left channel.
Oct 29, 2012 | Harman Kardon HK 3370 Receiver
Left channel won't play.
There could be a number of causes for this from as simple as a dirty switch to a power supply feed to the left channel being open. Without looking at the unit, it is had for me to say. Is it worth it? In my opinioon, yes. Figure on $5-$25 for parts.
Dan
Sep 27, 2008 | Harman Kardon Audio Players & Recorders
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Dell A525 Computer Speakers Logo
170 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
