Question about Denon AVR-3300 Receiver
Denon receiver AVR-3300: Unstable source selection
Denon receiver AVR-3300. Unstable source selection: after manually selecting an input mode, e.g. tv, after a few minutes every couple of seconds a different source is selected by the receiver itself.
    Scholar:
  • 74 Answers
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 42 Answers
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
I have connected an audio source to the optical input channel 3 on my Denon AVR3300 but cannot get any audio thru mu speakers. The CD and Blueray connected to channels 1 and 2 work fine. What other...
If you have the User Guide for the Denon 3300, go to the "setting the digital inputs" section. The input settings are in the on screen menu called "system setup menu", then move down to "digital inputs".
Make sure that input you are having problems with is selected properly to "Optical".
The Denon 3300 guide is a mess I know and not user friendly in the least.
I have been using the 3300 for 9 plus years with no failures.
Oct 13, 2010 | Denon AVR-3300 Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
I can not get the receiver to recognize more than one digital audio input. I am trying to use digital audio from my direct tv receiver, and my ps3 player. I have tried about a thousand things. the best I...
with all your digital connections made once you select that source press the input mode button on the front to select auto this should give you digital sound
Jul 05, 2009 | Denon AVR-1082 Receiver
Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Dec 20, 2008 | Denon AVR-3803 Receiver
Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
May 26, 2008 | Denon AVR-2105 Receiver
Denon AVR-3300 Receiver Logo
1,087 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
