Question about Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Front Load Washer Shrinking clothes
I can't figure out why my washer keeps shrinking clothes---mainly polo shirts. Help.
  • 213 Answers
Re: Frigidaire Front Load Washer Shrinking clothes
Check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Posted on Nov 20, 2007
0 characters
3 Points
Why does my machine shrink clothes on 40 degree wash
Some tissues are more sensitive to shrinking than others.
Some clothing cannot be machine washed or only at very low temperatures (hand warm).
Especially woolen fabric will shrink even at 40 degrees.
Be carefull with spinning at high RPM's.
Always consult the label in the clothing:
Jun 03, 2014 | Miele Novotronic Premier 500 Front Load...
Washing machine too hot
Turn down temp on your home water heater.
Apr 22, 2010 | Hoover HW160M Front Load Washer / Dryer
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to...
if your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Jan 03, 2009 | EuroTech EWF150 Front Load Washer
Washer is using hot water on the cold/cold was
Unless your hoses are reversed the machine control is bad and needs to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire front load washing machine gtlf490e
just change the door switch been there done that have the t shirt
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
This is a frequent complaint with the following known  solutions:
  • You might be drying them too long. back the time down so that the cool down cycle happens right as the clothes are dried.
  • Try smaller loads.
  • You should dry heavy fabrics and light fabrics separately.
  • Fabric softener in the washer may help to prevent wrinkles from forming in the dryer.
Feb 27, 2008 | Frigidaire GLTF1670A Front Load Washer
No cold water, only hot water in tub
Check first the filters on the cold inlet water line (both sides). Then, if problem is still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Sep 02, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
237 people viewed this question
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
