I have the light of the hard drive light blinking instead of being constant light and the hard drive dont want to start ??
  • 94 Answers
Check the data and power jack of HD if they are fine i fear u need a new HD
Posted on Jul 22, 2009
I plugged in my 1TB WD hardrive and noticed that it did not show up as the name I had renamed it instead it showed up as Local Disc. When I try to access it it just crashes windows, I tried this on my...
It could be that the drive was infected by a virus. The Virus dumps an file with the name autorun.inf onto the drive and everytime u plug the drive into a pc - it wants to run the virus that autorun points to.
Try something - unplug the hard drive, then press the SHIFT key and while holding it, plug in your hard drive. DONT let go of the shift key until the drive has been detected (around 10 seconds should be find) then let go of the shift key - if the drive shows up under "my computer" DONT double click on it to open it as that will jsut run the virus again ... instead .. RIGHT click on the driver and choose explore. If you can see the drive this time - it is a virus and the best option is to remove the virus or format the drive - post another question if this does not work.
Good luck
Feb 02, 2011 | Western Digital My Book Essential 1TB...
My Seagate FreeAgent Go 500 GB, stopped working in the middle of copying some of its data into my PC. Now instead of the constant light-up when connecting to the pc, it blinks continually. And the hard...
First i would remove and reinstall drivers for this device,next try device on another system if it works ok on another system drive ok if not drive has failed.Good luck!!!
Jan 08, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Why is my hard disk drive indicator light always blinking on my Sony Vaio Laptop? My laptop reads cds and dvds fine, it is just annoying to always see it blinking.
This is perfectly normal. Your hard-disk indicator light is always blinking because your hard-disk is constantly being used by the operating system. Windows and other applications are performing operations in the background which require both reading from and writing to the hard-disk regardless of whether you are doing anything or not.
You only need to worry when the hard-disk light STOPS blinking . . . permanently!
Nov 03, 2010 | Computers & Internet
When I t urn on my laci external harddrive I get a fast pace blinking light and when I put my ear to it, it seems that the motor wants to start running then nothing Just a constant blinking blue light!
It seems that you have a problem with the disk-drive inside the case. If it still is under warranty, exercise the warranty to get it replaced.
If not, then disassemble the case, and remove the disk-drive.
Connect it as a "slave" disk-drive inside a desktop computer,
to see if it can be read. If not, then it is "dead".
You could buy an identical disk-drive, and put it inside the case,
to construct a "new" external disk-drive.
Sep 28, 2010 | LaCie (300770) 250 GB Hard Drive
Blinking light
the drive is brocken and should be replaced if still under warent.
May 27, 2010 | FireLite (USBFLB80) Hard Drive
Light on front just blinks
this could be for several reasons. Normally a light blinking on a hard drive is to say that the disk is being accessed. but if it happnes for a long period of time, then you might have a issue with the disk itself.
i suggest that you try the device on another PC, a friends or relatives. if you have the same problem , i am afraid that you might have a disk error
May 06, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My Dell Studio 540 blinking hard drive light
the hard drive light blinks whenever the Hard drive is accessed, and sine this is where everything is stored, that happens a lot. the only way to completely disable it is to unplug it from the motherboard.
Jan 15, 2010 | Computers & Internet
Inspiron 1525 not starting up
Take out the memory and install them one stick at a time in each slot one at a time. As your doing this, turn on the laptop and see if the video comes back on.
If that doesn't work then take the hard drive out and the dvd drive out.
Turn on the laptop now and if you still dont get video then that means the motherboard is bad at that point.
Jan 06, 2010 | Dell Inspiron 1525 Laptop Jet Black
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
1,121 people viewed this question
David Payne
David Payne
