I live in rented premises and have the same/similar heater model. I am reluctant to pull it apart to clean it (as I know my Landlord won't bother) I can see the screws on the side and it seems to have detachable panels. My actual question is - after pulling out the bottom grill plate I found a plastic dish - is this model meant to have a water added to this dish? This is a very old model and it is fixed to the wall. It also has been giving off a bad odor. Any ideas?
It shouldn't give an odor at all unless it hasn't been run a lot or cleaned. Rinnai recommends blowing compressed air through the front grates once a year. The pan is to catch condensate from the venting system. Hot flue gases contain moisture, which is a byproduct of burning propane. When this hits anything below 212 degrees, it will condensate and collect in the pan. The heat from the unit evaporates the water, thus making it a good system of condensate disposal. However, additional water can be added daily if you have problems with dryness in the air. The only other thing that can cause a bad odor is a compromised heat exchanger. You should have it checked, and if you don't already, have a CO detector in the room
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater -...
The thermostat seems off as we have the temperature set at 60 degrees and, although the room...
(More)
The thermostat seems off as we have the temperature set at 60 degrees and, although the room temperature on the heater says 58, we are all moving around in short sleeves so it must be in at least the 70s! Is there a way to adjust the thermostat?
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however...
(More)
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however would like to have the heated air to blow from the front vents. How do I achieve this? My email add. is nwidmer@bigpond.net.au thank you Nick Widmer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I...
(More)
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I achieve this
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
