Question about Samsung NC10-14GW Notebook
Hard disk recognised but not show up in my computer
My problem is my external hard disk recognised but doesn't show up in My Computer. plez help me, how to overcome this problem
  • as_leyz Jul 22, 2009
    no i referred to my external Hard disk use USB cable...
    it make sound, i already try to connect at other computer but the same problem appear..when i check at USB properties show the status "This device cannot start. (code 10).
  • Samsung Master
  • 32,281 Answers
Check the BIOS configuration to see if it deects the hard drive.
When you boot up the Samsung, does the hard drive spin up, if it does not spin up or makes a clicking sound the the hard drive is faulty.
To get your laptop operating again, replace the hard disk and install Windows on the new hard disk.
Posted on Jul 22, 2009
  • 1 more comment
  • Chris Hingee
    Chris Hingee Jul 22, 2009
    Sorry I miss read your query, I thought you referred to the hard drive in the Samsung.
    Is the external hard drive an external USB hard drive?
    Is the power adapter for the external hard drive a separate unit and is the power LED on the hard drive on?
    When the external hard drive spin up and does it make a clicking sound? If it doesn't spin or makes a clicking sound then the hard drive is faulty.
    Try connecting the external hard drive to another computer and if it does not show up on this computer then it is faulty. If it see this external drive then it is OK and there is a problem with the Samsung.
    Get back to me with the answers to my questions and any error messages.
  • Chris Hingee
    Chris Hingee Jul 23, 2009
    You could have a faulty USB hard drive adapter case or a faulty hard drive.
    To determine which item is faulty, you need to identify the type of hard drive ie. IDE or SATA.
    To test the hard drive, remove the hard drive from the enclosure and connect it to a different USB hard drive adapter and connect it to a computer. If it still not detected or started then it is faulty.
    To test the hard drive a different way, insert the hard drive into a desktop computer as a slave drive. If the computer's BIOS doesn't detect the drive etc. then it is faulty. (If the desktop doesn't support SATA devices and the hard drive is a SATA drive then you can't test it).
    The USB method is my preferred test method.
  • shahie Sep 27, 2013
    how to solve it then? does the hard drive cannot be use again?
How do I fix an external hard drive not bieng recognised by my computer and does not even show on disk management on the computer?
Try turn on of several time.Check out for new cable.Open case to see if everything is attached or unplag.
Instal new driver for ide controler on your motherboard.
Aug 07, 2012 | Toshiba Computers & Internet
My laptop doesn't recognise external hard drive
Most Windows versions:
Go to the diskmanagement (run compmgmt.msc) option Disk management.
Locate the drive and add a driveletter.
If the drive is not shown in the list, you need to check your USB drivers or connectors.
Jan 15, 2012 | Medion Computers & Internet
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
My hard drive is recognised by windows and shows the memory used but shows no files - comes up as empty. I have done a disk check and this reports that there is no problem. I have also tried this on 2...
did you turn of your computer or click on remove hardware safelty link before diconecting this external hard drive if it shows how much is being used it is being recognised you could run the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start might or might not schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 08, 2011 | Western Digital Wd Elements Se 1tb...
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
I put my old hard drive in as a slave, vista recognises it in management and device manager but doesnt recognise it in my computer?
it might need to be formatted, right click on the computer and click on manage, click on disk management and format the disk.
Mar 03, 2010 | Acer Aspire m5640 PC Desktop
I have about 39gb of family pics and music saved on my freecom 250gb external hard drive and I have had to reboot my system with a backup file using ACER e-recovery management. since then my external hard...
In the control panel, go to administrative tools, open computer management. On the left side, there will be a "Disk Management" section, use that to assign a drive letter to your hard drive.
Sep 30, 2009 | Acer Aspire™ T180 PC Desktop
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Samsung NC10-14GW Notebook Logo
430 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
