Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer omt HiLate 90's omt cd juke will pull cd out of rack...try to start 4 times then returns cd to rack. I thiught I had read about a problem or failed part that would cause this condition. It does it in every cd. And assistance and parts availability would be great. Thanks
    Problem Solver:
  • 8 Answers
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
Posted on Dec 27, 2007
The problem is with the cd player. the bad newsw is you probaBLY have a cdm4 player which is no longer made. wurlitzer makes a kit to convert it to A cdm12 but it is a few hundred dollars
Posted on Nov 15, 2008
  • Wurlitzer Expert
  • 211 Answers
The fault is with the Cd player or CD control PCB. It spins the CD once to read the track information. If it can't read it, after a few tries it returns the CD to the rack. First thing to try is to clean the 'eye' on the laser unit with a cotton bud and meths. After that, you have a laser unit problem (probably).
Dave F.
Posted on Aug 06, 2008
I have the same problem
Do you know where I can order replacement parts
Posted on Jul 14, 2008
How do i replace the cd laser on my wurlitzer omt
Unless you have specialized equipment to align the laser, do not try to change the laser. That being said, when I have problems with a CD juke that I track down to the player, I change the whole player (the silver unit about 4"x6"). Enco systems .net has new and rebuilt CDM-pro players. If it as older one, other places rebuild them. Enco has a list of player symptoms on their home page to determine if you need a player.
Aug 04, 2014 | Wurlitzer Jukebox 1015 One More Time...
Just purchased second hand wurlitzer 1015 omt with ipod and cannot get the ipod to work do i have to programme the box to play?
The iPod should play automatically if plugged into the docking bay. There is a design fault which means the cable on the back of the docking bay gets dragged out if the title rack is dropped down. Check the cables and push them home.
Jun 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer omt K99 the cd will stop during play
I seem to be having the same problem and all signs point to the serial control board board Pt# 0046630 under the player. The symptoms with mine were randomly cutting off songs about 20 sec after song start and returning disc to carrier. It started mostly when juke was first turned on (cold) and then progressed to all the time and now display on cd board is dark only randomly coming to life then dead again. power on the sub transformer is good and when it comes to life player works well. I am sending the board to be repaired.
Feb 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Mar 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
562 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
