Question about Dell Inspiron 5160 Notebook
Exactly same as this post.
Basically my power charger packed up due to a frayed wire. The laptop was in standby mode but the battery (which never held a good charge for longer than 10 mins as the machine is a good 4 yrs old) must have gone dead. Having bought a new power charger I can not get anything to work. I can use the shift key plus power on but get exactly the same results as the previous post i.e. altrnating green and yellow lights on front of machine and num lock light permanently on as well as the fan but NO screen. Machine will not turn off unless power cord removed together with battery as power button doesn't seem to function either. Is this a terminal problem and it's best just to get another lap top, or is it fixable for no or small cost?
  • Dell Master
  • 32,281 Answers
This laptop could have a faulty RAM or motherboard, reseat the RAM memory module, to make proper electrical contact.
Next go into the BIOS configuration the check the system, hard drive etc. If this doesn't work then most likely the motherboard is faulty, especially if the Caps and Num lock LED lights are either locked on or off.
If the laptop is dead I suggest you put your money towards a new laptop, and if the hard drive is OK then remove it and put it into an USB hard drive adapter case and use it as an external USB hard drive (storage device).
Posted on Jul 22, 2009
    President:
  • 828 Answers
After that frayed wire then you have trouble with your laptop again, i am a technician but supposed to see that personally that laptop it should be good for now. The keyboard is malfunction already, i mean it hang-up, all the lights are on and it cannot turn off unless power cord remove. This time i diagnosed that your laptop have a problem inside, call a technician.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
My Inspiron 1521 enters standby mode randomly and without command to do so.
How about the battery backup - computer goes to stand by mode automatically if battery fails in power .
check whether computer goes in standby on battery only or when pluged in charger also
Oct 04, 2010 | Dell Inspiron 1521 Notebook
How to maintain compaq cq 40 to get better battetry backup for more than 2 hours
Tips for getting more from a notebook battery.
1. Turn off Wi-Fi and BlueTooth - Most laptops have shortcut keys to instantly disable wireless networking.
2. Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
3. Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
4. Adjust your screen brightness - Dimming your display saves battery power.
5. Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
6. Decrease or mute the Laptop Speaker Volume.
7. Turn off all scheduled tasks.
8. Turn off Auto-save features in Microsoft Office and other applications.
9. If your PC has a built-in wireless card, turn it off or disable it when not in use.
10. Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Looking for the longest battery life laptop ? Actually, many factors affect the amount of time that a laptop battery can deliver power before it must be recharged.
How to extend laptop battery life? Here are some more tips to improve your notebook's battery life:
1. If you do not use your laptop for extended periods of time (a week or more), remove the battery pack from the laptop.
2. Do not expose the battery to high heat or freezing temperatures. Do not leave your battery in your car in the summer. Hot batteries discharge very quickly, and cold ones can't create as much power.
3. Make sure to plug your laptop charger adapter into a UPS and not directly into a power outlet or surge protector.
4. If you have a nickel-metal hydride battery, completely drain and recharge the battery once a month to maximize its capacity to hold a charge.
5. Fully charge new battery packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity.
6. For laptops that work as Desktop Replacement, the battery should be re-installed every 3-4 weeks and allowed to fully discharge.
7. Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Battery-saving sleep modes: Should I use Stand By or Hibernate
Standby mode
Use standby to save power when you will be away from the computer for a short time while working - your monitor and hard disks turn off, all applications and open files are stored in RAM. When you want to use the computer again, it comes out of standby quickly, and your desktop is restored exactly as you left it.
Hibernation Mode
Use hibernation to save power when you will be away from the computer for an extended time while working - your computer shuts down to save power but first saves everything in memory on your hard disk. When you restart the computer, your desktop is restored exactly as you left it.
When you choose Start, Turn Off Computer in Windows XP, your options are Stand By, Turn Off, and Restart. To Hibernate, place the cursor over Stand By, then hold down Shift and click.
Jan 12, 2010 | Computers & Internet
We have managed to lose the rechargeable battery pack. Where can I get another one?
Oh my, not good. Well, you do need a battery pack. Contact the MFR for replacement pack via customer support, or check the voltage on the side, if using 9V, get a battery holder that uses 8 batteries[2 Xtra cells are used to disable the shutting off at too high a voltage due to the missing battery pack]go to battery space.com, and go to wires/connectors, and get the laptop connectors to make an external battery pack. Therte is a battery pack charger/I recommend accupower evolution. You have to google and go to other sites to get the rechargeable batteries and battery holder. You can get by with alkaline, but they would go rather fast due to the large screen size. You need that good brand name so they can be evenly charged due to the batteries being able to be run down further. You wont be wasting much voltage with alkaline due to the lower cutoff voltage, but 1st try contacting the mfr or googling to get that battery pack!!!I Hint: if using battery pack and you still want to add more battery life, drop the batteries to 6 on a 9V circuit. with original battery pack on, a 9V circuit would use 6 D cells on an external pack, 8 for a 12 volt.
Aug 17, 2009 | kawasaki PVS-10921 Portable DVD Player
My laptop doesn't open when i try to push the on button..help?
it is basically a hardware problem since your hardware(laptop) didn't respond when you turn it on. Are you running on battery mode or AC mode? if you're on battery mode try to check your battery it may be fully drained. Try to switch to AC mode by plugging into your AC adaptor/battery charger and see if it works.
Regards!
Jul 17, 2009 | Computers & Internet
The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Mar 13, 2009 | Onkyo TX-SR605 Receiver
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Dell Inspiron 5160 Notebook Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
