I've got a 22inch bush tv and need some display drivers to use it with my pc. It does work but the maximum screen resolution is much smaller than it should be
  • Sean Hope
    Sean Hope May 11, 2010
    What screen resolutions are supported by the tv?
campus
  • 56 Answers
SOURCE: Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Posted on Dec 05, 2007
myob247
  • 1342 Answers
SOURCE: Cannot change screen resolution-driver not installed
If right clicking on your desktop and choosing properties does not work for adjusting your screen resolution, Click HERE to go to the Dell driver download site for your pc model to update your video driver.
Posted on Jun 03, 2008
SOURCE: Display resolution problemw with Dell Inspiron 8000
I had the same problem you described as small screen in the middle with black border around it. The only resolution that made the screen fill the LCD panel was 1024 x 768. THAT IS WRONG!!!
Dell Inspiron 8000
PROBLEM - Small Screen in the Middle
FIX THIS PROBLEM - Try (Function Key + F7)
Posted on Nov 25, 2008
  • 3940 Answers
SOURCE: Dell Inspiron 2200 maximum display resolution
The display limit is determined by the LCD design. IN this case, you have an XGA LCD resolution 1024 x 768 pixels. This is a hard wired resolution and can only be changed by exchanging the XGA LCD for a higher resolution one (SXGA or higher, likeky not an available option for an Inspitorn 2200)
http://compreviews.about.com/od/multimedia/a/LCDSpecs.htm
Posted on Apr 19, 2009
SOURCE: What driver do i need for my pc for the resolution to be right...
i also have this problem but never got a disc with it when i bought it, any ideas please
Posted on Aug 07, 2009
I have Sony VAIO VGN-SZ2XP/C, installed Windows 7 All fine except the display is smaller than the display screen.
right click anywhere on your screen, find the screen resolution tab and click on it. change your display to 1920 by 1080. if this doesn't work, try a few of the other screen resolutions.
Feb 15, 2015 | Sony Computers & Internet
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
How to maximize my computer screen and keep it that way
Maximum is for a window. For example when you open a program or a internet browser, then in the upper right hand corner just to the left of the X will be the minimize or maximize toggle that you click.
If you are talking about your screen resolution which makes icons bigger or smaller then that is in the Display in the Control Panel. Click Start/Control Panel or Start/Settings/Control Panel and look for Display or Appearance and Personalization. Open it and adjust the screen resolution. The higher the resolution, the smaller the icons.
May 31, 2012 | Dell Computers & Internet
My display exceeds the screen dimensions. Icons, menus and taskbar are all out of the screen image. Please, what is the problem and how do I fix it?
In your display settings you set it to display larger than the maximum size of the monitor it supports. for a netbook. it is might be around 1024x576 depending on your model. it can also be 1024x600.. Go to your display settings in control panel and click on display or right click on your desktop and go to preferences. you can adjust your display settings there.
Mar 22, 2012 | HP Mini 1000 Netbook
The scrren either says resolution is not supported (mode 1) or the screen wiggles and shakes (mode 2). A directly connected pc works fine. I am sending to a tv with pc input as the remote display
The QVS VBC5 video extender supports a maximum resolution of 1600x1200 @ 60Hz for up to 50meters (164feet) & 1024x768 @ 60Hz for up to 100meters (330feet).
Make sure your maximum distance of Category 5 cable from your source to your television is no longer than 330 feet if using a 1024x768 resolution. Try dropping the resolution on your source computer in Mode 2 to resolve the issue.
Mar 29, 2011 | QVS VBC5 VGA/RGB Video CAT5e Extender ...
I recently installed a series of drivers for my Vaio VGN-TZ17GN running XP and while all others work fine, the video driver has reset the display resolution from the original 1366x768 to 1024x768 and...
If you're using the newest driver, it should support the physical display's maximum resolution. If your old display driver worked fine, roll back to it. If you can't, then you need to contact Sony to find out where to get the proper driver.
Mar 27, 2011 | Computers & Internet
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
Graphics problem
First of all, note that the maximum resolution of your screen is 1024x768... any higher is simply not possible (unless you hook up an external monitor)
If the maximum resolution (in Display Settings) is below that, you need to update your graphics driver. To do so, follow the steps on this page.
Hope to have helped,
tS
Dec 10, 2009 | Compaq Presario 700 470024-192 Notebook
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
Televison & Video Logo
691 people viewed this question
Top Televison & Video Experts
Electro Med Services...
