Question about Microsoft Windows Vista Ultimate Edition
Built in windows vista in acer pc recovery
My computer suffers from frequent hanging at first. when i have installed a game, and when it's in use, it always hangs and cannot be used till it comes a point that it cannot logged in to windows vista. it will just boot and restart again and again.
    President:
  • 828 Answers
Your display graphics is in trouble but not actually the Physical VGA Card, only in the system.. if you still have that problem then reinstall your system again.
Posted on Jul 22, 2009
I have a Acer Aspire M5641 Window vista and lost my Recovery disks. My computer crashed last week. Can I install Window 7 in the computer? Do What kind of driver do I need to install Window 7? Thanks,
You probably can install Windows 7. You will have to go to Acer's site to get any special drivers, But to start, just insert the system disk and do a fresh install.
Jun 20, 2011 | Acer Aspire M5641 PC Desktop
I was installing Windows 7 over Vista on an Acer Aspire 11.1 netbook with 2 Gig of ram. The system crashed (the chronic problem with Vista that I was trying to fix). Now I'm in a loop where Windows 7...
Have you tried to press F8 when the system boots ( initial screen ) and tried the safe mode or last known good configuration ?
If this does not help, try a recovery disk and it should work.
Regards,
Ron
Feb 11, 2011 | Acer Computer AO751h-1145 Aspire One 11.6"...
I have a Toshiba L200 laptop running on Windows Vista. It hangs frequently and sometimes restart on its own. Thinking it a windows problem, I re-format it and install a fresh Vista OS using the systems...
It sounds like you have some drivers missing. Don't worry If you log on to www.computers.toshiba-europe.com click on "click here to find your laptop" under the heading "support my product" (left hand side of the screen mid way up).
It will even look up all firmware and software upgraded and help you to install them.Hope this helps.
Oct 29, 2010 | Computers & Internet
I have a Acer Aspire 5315 series I need Vista software to get my system fixed from virus
First look for Acer recovery from your computer, there should be acer erecovery management program or similar on your computer that may have a option to burn recovery disks or to restore the computer automatically.
if you don't have that option in your start menu or you can't locate the software from your computer Then try the recovery partition method in the start up of your machine.
Acer machines should have a build in recovery, hold down ALT and press on F10 repeatedly when you power on the machine, keep pressing every 2 seconds until acer recovery comes up, if it doesn't come up then your machine probably doesn't have that option, the laptops mostly have it.
If you are unable to do any of the above then you may be able to order recovery discs from ACER -- https://secure.tx.acer.com/RCDB/Main.aspx?brand=Acer
If that link doesn't work, copy it to your addressbar and press enter.
If you end up with no way to restore or no restore media, you would have to get your hands on a windows installation cd.
I've written instructions for how to install windows XP, Home, pro, etc. windows Vista, and windows 7.
You can find those instructions here
XP - http://www.fixya.com/support/r3575559-step_by_step_howto_install_windows_xp
VISTA and 7 - http://www.fixya.com/support/r3575598-step_by_step_howto_install_windows_7
Dec 25, 2009 | Acer Aspire 5100 Notebook
PC hangs randomly
This may be problems inside your computer, for instance, your power supply could be bad or intermittent.This could cause this problem. Any loose connections or bad connections in the computer can also cause this problem. This could also be a hard drive problem, if the hard drive is not functioning correctly. This unit should be return for service and problem should be listed as intermittent hanging problems. This problem could also be a lot worse like a bad cpu chip or motherboard.All the service information should be in your owners manual. Hope this helps you with your problem.
Apr 21, 2009 | Acer Computers & Internet
Acer3690 windows vista wont start back up
If Vista came installed on the computer originally you should be able to just run a system recovery (either from the had drive or from recovery discs made after buying the computer). When turning on the computer press Alt+F10 to start the recovery process. If you get a loading bar with "Loading Windows Files" above it then you're on the right track. It will allow you to reinstall windows Vista and will also install all the drivers you need.
If you can't get the Alt+F10 to work and don't have the recovery discs then you will either need to contact Acer and get a sent shipped to you, or find someone with a set of OEM discs that can reinstall it for you.
Hope that helps :)
Mar 25, 2009 | Acer Aspire 3690-2196 Notebook
Acer Internet Problem.
go to the Acer website and download the drivers for your make and model laptop if you do not have  teh original driver disks that came with your computer.
If the computer has a recovery partition, check and see if one of the recovery options allows you to restore drivers only.
If your acer cannot access the internet because you do not have drivers for the direct or wireless network connections, you can still access the make and model support and drivers files from the Acer web site and burn to a CDROM or save to a jump drive to install on your laptop - or you can request a driver CD for a small $$ from Acer.
Dec 10, 2008 | Acer Aspire 5315 Notebook
Reformating
You need to have a windows vista dvd or a recovery/restore cd from Acer. CD-less installation will only work if your computer has a restore image which should be installed in the factory. I dont think acer dekstops have that though.
Just call Acer and ask for a vista dvd or see if you know someone who owns a computer which came with the same version of vista and borrow their dvd.
Oct 04, 2008 | Acer Aspire™ T180 PC Desktop
WIreless Controller
if you just want drivers for windows XP, try this link:
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=322802&CFTOKEN=91496331
If you want to completely reinstall Vista, to factory defaults...
First, if you created backup disks when you first purchased the computer, you could use those.
Second, i'm not certain if this will work on this specific model, or after the changes you made, but there MIGHT still be a backup partition on your hard drive:
to TRY reseting to factory defaults from the hard drive, press alt-f10 when you first turn on the computer, and hold it down until a recovery screen comes up.   I don't know if that will work or not.
Third: you can order a recovery CD from Acer here:
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Mar 29, 2008 | Acer Aspire 5610-4648 Notebook
Windows Vista hangs while browsing
An operating system hanging indicates that either the program you are using, or the operating system itself, has crashed. The easiest way to eliminate hangs is to start up the computer from your Windows installation disc, and then either choose to Repair your installation, Restore the installation or install a new Windows OS.
Your computer came with a recovery option that lets you "reset" or recover to a known "good point". Hold down the "Alt" key and then hit the "F10" key (both at once) to activate the feature, and then follow the on-screen directions.
Nov 09, 2007 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
