Philips CRT Monitor 107 E66 SMPS dead Pls any one
Philips Monitor 107 E66 SMPS dead Pls any one having its schematics
  • 6,993 Answers
Hello, welcome to Fixya!
Your monitor is having a power fault because it is not switching on. The monitor might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the rmonitor.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the monitor, it goes straight into the power supply board which then circulates the current into the unit. So if the monitor doesn't power on, the first thing is to make sure there is power entering into the monitor.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Jan 05, 2012
  • 528 Answers
The monitor might be 'dead' because the flyback transformer (specially primary section of it) is not working. You can try replacing it if it doesn't cost you too much.
Posted on Jul 24, 2009
Tv philips 21pt2443 schematic diagram
Schematic diagrams are in PDF, and cannot include by this window. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 23, 2014 | Televison & Video
COMPAQ 7540 CRT Monitor servicemode pls provide me. Thanks.
You could try this link, but it would be far cheaper to upgrade to a new or second user LED/LCD monitor
http://www.eserviceinfo.com/index.php?what=search2&searchstring=schematics+diagrams+hp+7540+crt+monitor
Sep 03, 2013 | HP COMPAQ 7540 CRT Monitor
Philips 107 E5 Monitor; display compressed into lower half
This is partial frame collapse and can be caused by a power supply issue supply the frame driver or the frame driver circuit has a problem with an IC or driver transistor. It should be relatively cheap to repair at a computer or TV shop but you may want to consider buying a cheap replacement monitor from eBay etc as the repair may cost you more than the replacement given everyone seems to be dumping CRT based monitors in favour of newer LCDs etc.
Aug 30, 2009 | Philips (6G3B11) for 107E51, 61, 107T51, 6...
I have problem with computer monitor philips 107 s, the brightness everytime show on, cant not hide.
Sounds like a stuck menu button. dose it cahnge to the next setting such as contrast when pressing it. If not, I would carefully take the monitor apart,
Stay away from the big red wire going to the top or side of the tube, it can carry thousands of volts.
Pull the circuit board out and and locate the front control buttons. See how do the feel. Dose one feel diffrently when pushed compared to the other ones? Check for any thing broken.
Aug 09, 2009 | Philips Standard 107S 17" CRT Monitor
Monitor ,crt, 17inc, in dead condition.(hcl)
He means it's not worth repairing it's cheaper to get a new one its value is zero $
Aug 04, 2009 | ViewSonic G70fB (Black) 17 inch CRT...
Schematic for Philips 27PT6441
I don't have the schematic but there is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
May 15, 2008 | Philips 27PT6441 27" TV
Philips 107C55
no its not a virus the problem is your monitor itself.try to contact an expert technician of monitor.i think there is a part of your monitor that is already defective.
Feb 16, 2008 | Philips Brilliance 107 17 in. CRT Monitor
Philips 104 series monitor
pls help my philiphs monitor 105s vertical probelum i need service manuval pls help
Feb 14, 2008 | Philips Standard 104S 14" cRT Monitor
Monitor hookup
http://www.eserviceinfo.com/downloadsm/4253/philips_107b.html
this is the manual please go through it
this will solve your problem
 good luck.
Oct 17, 2007 | Philips Brilliance 107B 17" CRT Monitor
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
