What does L6 mean on my Garrison carbon monoxide detector, it beeps then that message flashes, and then it beeps again . It is a plug in and does not need a battery.
Lb (rather than L6) indicates a low battery. You need to replace the 9V battery in the carbon monoxide detector. The Err suggests an internal error but could just be due to the low battery.
If the Err persists after you replace the battery, press the peak level button (the right hand button) and check for an additional error code. If the Err message continues, replace the Night Hawk unit. If the unit is still under warranty, contact the manufacturer. Most of these units have a 10 year warranty. There are several models available from Kidde. The manual is available on the product site. For the KN-COPP-3 Night Hawk carbon monoxide detector, the documentation is available here: http://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-copp-3/ . Click on the Documents tab. The manual for the KN-COPP-3 999-0100 is here: http://www.utcccs-cdn.com/hvac/docs/2001/Public/06/User_Guide_KN-COPP-3_900-0100.pdf .
L6 is actually "Lb", which is a low battery warning. If the 9V battery is missing, or if the battery's power is low, an "Lb" message will display, which blink's alternately with the current CO reading, while chirping. If this happens, you need to replace the battery.
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
