Question about Whirlpool ET4WSKXS Top Freezer Refrigerator
Freezer woks fine but the fridge not working
The freezer is working fine ,but the fridge is not working and i can see ants getting inside the fridge and eating the fooditems
I had same issue previously , but after 6 7 days it got working by itself.wat can be the reason for that?Can anyone help me?
  • 534 Answers
Sounds as if the evaporaator fan inside the fridge between the fridge and freezer is out. This fan is located between the freezer and fridge in the same area as the control switch for the temp. This fan isn't hard to replace you just need to take care of the removal of the plastic cover. Once the cover is removed the fan is accessed easily. Take the model and serial number to an appliance parts house for the proper part. Good Luck
Dave
Posted on Jul 22, 2009
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Water in fridge coming from freezer
the drain line in the frezzer is blocked
Jun 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
My freezer works fine, but the fridge doesn't
The air channel from the freezer to the fridge is probably blocked. Give it a full defrost to melt the ice from the cooling fins inside the freezer walls.
Mar 20, 2009 | Refrigerators
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
Whirlpool ET4WSKXS Top Freezer Refrigerator Logo
118 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
