Question about Acer Aspire One Netbook 8.9" Notebook
My laptop wont boot up
My latop wont boot up . I boot it up and all it does is show the start up light and the power light but it wont show anything on the screen.. can some one help me please! it a apire one notebook laptop computer
cindy
    President:
  • 2,291 Answers
Use a Windows startup disk:
One of the first things you should reach for whentroubleshooting a Windows XP boot problem is a Windows startup disk. This floppydisk can come in handy if the problem is being caused when either the startuprecord for the active partition or the files that the operating system uses tostart Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk intothe drive of a similarly configured, working Windows XP system, launch MyComputer, right-click the floppy disk icon, and select the Format command fromthe context menu. When you see the Format dialog box, leave all the defaultsettings as they are and click the Start button. Once the format operation iscomplete, close the Format dialog box to return to My Computer, double-clickthe drive C icon to access the root directory, and copy the following threefiles to the floppy disk:
Boot.ini
NTLDR
Ntdetect.com
After you create the Windows startup disk, insert it intothe floppy drive on the afflicted system and press [Ctrl][Alt][Delete] toreboot the computer. When you boot from the Windows startup disk, the computerwill bypass the active partition and boot files on the hard disk and attempt tostart Windows XP normally.
After restarting windows use a system utility software like RegInOut.
Posted on Dec 30, 2011
  • 43 Answers
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Posted on Jul 22, 2009
When i turn on the latop it says gateway and also says repairing pc and it wont go any further
try turning on your laptop in safe mode with command prompt by hitting f8 on startup,
try to check your your hard drive on typing "chkdsk" command. it will show the status of your hard drive. if it doesnt work theres problem with your hard drive
Apr 27, 2016 | Gateway Computers & Internet
It start power only
If it seems like the latop booted up except the screen is black try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If the laptop does not start at all try the steps below.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 26, 2012 | Compaq Computers & Internet
Acer aspire 5935G laptop wont start
Reasons for this issue:- Contact acer tech support and ask for the operating system cd, you may need to re-install your computer- Possible Hard disk problem and it need replacement.
Mar 14, 2012 | Computers & Internet
My externa 5635 laptop-when I plug in power cod-Latop show its POWER LED.when I want to start it. Its not start. become totally POWER OFF. when eject BATTERY, then become as it is.
Make sure your plug is connected firmly to the powerbrick and that there is no dirt in the connectors of the battery. Also try a different adaptor.
Sep 06, 2010 | Computers & Internet
My acer extensa 5220 doesnt charge and there are nil lights showing. How do i test the battery adapter. Or please suggest other options to try.
Unless you have a voltmeter or multimeter, then you can only test your battery charger by removing your batter and try to start up your computer with only your charger plugged in. If it boots up, then the problem isn't likely to be with your batter charger, but with the battery itself. Sometimes an adapter will power up a latop but not charge the battery.
Jun 15, 2010 | Computers & Internet
IBM t43 laptop wont power up
did you try to check if the power supply is working properly coz if no lights at all it means no power is coming.
Sep 16, 2009 | IBM ThinkPad T42p Notebook
Wont boot up no matter what...just shows battery light and z lite
Remove the battery and disconnect the AC adapter. Press and hold the power button for a minute. Then connect the battery and AC adapter to turn on the notebook.
Aug 19, 2009 | Computers & Internet
Toshiba satellite P105-S6104 DVD Rom wont open
If brand new return for replacement! It is fubar - supposed to be recognized by CMOS and your OS.
Sep 09, 2017 | Toshiba Satellite P105-S6104 Notebook
Boot up problem
Has the power connector at the rear been damaged at all? It sounds like there is no power getting to the laptop.
Dec 29, 2007 | Computers & Internet
HP Pavilion DV2036e Wont Boot
similar cases,,,,,,,,won't boot,,,,,1.) if with black display; please check your ram memory, if you have 2 take out it all and replace it one by one, try to boot one at a time,,2.) if with black display and the pan start functioning maybe your cpu is dead, try to switch it to another computer with thesame socket and voltage,if this computer won't boot also,maybe you got the answer.........hope to help
Dec 24, 2007 | HP Pavillion ZV6000 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
358 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
