Question about IBM ThinkPad T43 Notebook
My hard disk is not detected by the motherboard as when it is pressed by the thumbs then motherboard detect the hard disk and hard disk light blinked up
  • 43 Answers
Hello! i think the harddiks IDE cable is not seated correctly i mean theres little contact to its slot .
If you can try get another IDE cable
good luck
Posted on Jul 22, 2009
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
My system is turn off and turn on no loading os and bios is not working motherboard is intel d102ggc2
Have you tried pressing F2 when you powered on the PC?
Ensure that the monitor displays the signal of PC and there is no issue with video signal. If there any issue, check with RAM.
1.If no, just press it to view the bios setting. Go to the third option below.
2.If yes and no display of bios, may be your BIOS ROM chip failed. Before that take the C-mos battery out and try again. Almost try to replace it or you must go for a new motherboard.
3.If yes and getting into bios, check for the hard disk detection. If it is detected, try again for booting. If it is detected and not booting, try to format. If it is not detected, try changing it into another SATA / IDE port. Still it is not detected, replace the hard disk.
Aug 19, 2011 | Intel D102GGC2 Motherboard
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My computer stopped suddenly and did not detect hard disk
restart your cmos by removing the battery on your motherboard and if that doesn't work update your bios.
Dec 20, 2008 | Intel D845GVSR Motherboard
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
My Mother Board Does Not Detect My Hard Disk
Hi, I will assume that you are referring to the "Mother Board Does not detect 160GB SATA Hard Disk" when installing Windows. You need to press F6 when asked if you want to install other driver and follow on screen instructions. Good luck and post back how things are or should you need further information.
Aug 22, 2007 | Intel Motherboard
IBM ThinkPad T43 Notebook Logo
177 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
