I have no manual and no clue
We have a Dyna Glo Pro #RMCKFA170TDGP. The shop guys say it wont ignite and I have no manual to troubleshoot the problem. Where can I find the manual, search engines seem to be useless.
  • 6 more comments
  • Anonymous Jan 31, 2008
    Heater comes on but won't ignite.
  • Anonymous Feb 23, 2008
    heater turn on ,but cuts off. it will not stay on longer than two min. thanks for any suggestions.
  • KJRE Mar 23, 2008
  • seven_spring Jul 14, 2008
    I have a mr . heater, and it worked last night, and egnited just fine, today it will not egnite. there is a spark , when I push the sparker, but no hissing propane comes out. Could it possably be plugged and how do I fix it so it will work. It hasnt been used alot and should work fine. email me at thanks for your time. betty fox
  • mproux Dec 06, 2008
    the pilet goes out after a short period of time or if you turn it to heat, and i lost the manual so i have no idea what to do. please help me.
  • Ku Jan 14, 2009
    Heater will light and fan will run when when I start it but as soon as I release the knob the gas shuts off. I also lost my mannul and would like to get a copy.
  • Jim Weaver Jan 16, 2009
    Same problem. Turn it on but no buzzing from the igniter. Don't have a manual. Search engines are worthless.
  • mammoth1964 Feb 05, 2009
    pilot heats up but isn"t lighting. vanguard model#kv140
After not finding any help on the Internet, I went to Home Depot to see if they could help. I deduced through my own that the ignitor has failed. (symptom: Turn on the heater, no buzzing, no ignition, heater turns off, light blinks). It's the nifty little black box that has two white wired leading to the circuit board, and two thick black wires going to the spark plug. Of course, Home Depot doesn't carry parts.
They had one Dyna Pro heater on the shelf. My wife found a phone number on the box. We called it and sure enough, we found the company and was able to order the replacement ignitor over the phone. Total cost: $33.00 (Including shipping).
IS HELP OUT THERE. Here's the info:
GHP Group.
7500 Saint Louis, Skokie, IL 60076
The replacement part is part number: 39E0002500
It fits models: RMC-KFA125TDGP, RMC-KFA170TDGP, and RMC-KFA70TDGP
Hope this helps.
Posted on Feb 07, 2009
  • 625 Answers
Try this site - [] there is a section on dyna glo products. if this is propane or kerosene the fuel path is ALMOST the same. A kero unit uses a small air compressor mounted on the back of the fan motor and supposed to produce 3.5 psi to supply air to the venturi in the fuel nozzle.
Posted on Dec 07, 2007
    Problem Solver:
  • 7 Answers
Check output filter and see if its dirty. I have a 210k heater that wouldnt fire .e1 was trouble code. changed filters( 3 in all) set psi back to spec and mine runs fine.
Posted on Jan 14, 2012
  • jandmrock
    jandmrock Jan 14, 2012
    check output filter and see if its dirty. I have a 210k heater that wouldnt fire .e1 was trouble code. changed filters( 3 in all) set psi back to spec and mine runs fine.
Help I have a Dyna Pro 40.0 and it will not light. Cannot get gas thru the burner, gas comes out of the valve. How do you get the burner apart? Is there a control module inside the burner? Insider the burner tube there's a large brass nut in the center, but will not come loose without fear of breaking. does anybody know the contact number of this companies customer service dept. Looking for answers?
Posted on Feb 06, 2009
  • Ron Farkas
    Ron Farkas Feb 06, 2009
    Just received info on Dyna Pro heater - company folded product parts not available - made in China - JUNK IT !
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
Dyna glo pro forced air heater won't ignite?
I've had mine for about 8 years now. Just started spitting out fuel and failing to ignite. Took it all apart and found a couple of cracked lines where they went on to the fittings. One was to the air pump and the other was a fuel line at the manifold. Cut them both back and reattached, but it still wouldn't ignite. Then I checked the pressure coming off the air pump and it was at 2 psi, should be at 3.4 on mine. Adjusted the fuel pressure up and bingo, it lit right up as soon as the pressure was right.
Jan 02, 2012 | Dyna-Glo Heating & Cooling
Dyna glo pro model #rmc kfa 125tdgp flashing code e1
I have same heater and problem-1) Check fuel inlet screens at bottom of hose in tank 2) Check air filters at fan module opposite end of the fan blade 3)Check for spark in ignition chamber 4) Check for fuel flow in ignition chamber (look at pressure gauge at opposite end from air exit) You'll have to remove the top cover to do these checks. The side covers will hang on each side ok. I hope these checks help you out.Good luck.
Jan 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Heating & Cooling Logo
1,559 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
