Question about SanDisk Sansa m240 MP3 Player
Problems with sansa 1gb express model BB0704UIB
  1. my jump drive is not showing in my computer
  2. it only display sandick for 5seconds and then it goes died
  3. battery is ok
  4. when connnected to the computer it sometimes show on the display screen that it is connected.
  5. it usually work great but stop workin two months ago
Re: problems with sansa 1gb express model BB0704UIB
I had the same problem. The following is the result of a tech support call to SanDisk that fixed my player, but be aware that this process also formats then re-creates the default folders. Be aware that YOU WILL LOSE ALL MUSIC AND RECORDINGS STORED ON YOUR DEVICE, including the sample music included with your player.
With that warning out of the way, here's what fixed my player:
1. I downloaded the latest firmware update from SanDisk's website.
2. I put the player on hold (orange strip showing) and plugged it into my USB port while holding down the (-) volume button.
3. I ran the SansaExpressUpdater.exe (from step 1).
4. After a couple of minutes, the update was complete and my player is working.
Posted on Dec 11, 2008
Have you tried holding down the power, up volume, and down volume at the same time for 5-10 secs? Sometimes my sansa spazzes out where it wont turn on with the power button and the comp wont recognize the device. Holding those 3 down for about 10 secs resets it.
Posted on Sep 04, 2008
0 characters
3 Points
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Sansa mp3 player not switching on
That sounds like the serial number. You are in a service menu of some kind. Get the Sansa Recovery Tool from Sandisk's website and run it.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Sandick sansa e250 player
Download the Sansa Recovery Tool and run it.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa displays "no song"
Could Be An Unrecognisable Format
Try Download Them In MP3 Format
Sep 30, 2008 | SanDisk Sansa MP3 Player
Sansa express shows "sandisk" in the display for 5 seconds and then dies. model - BB0704UIB it flashes sandisk for 5 seconds and dies
Well it shows the lock on the screen because you have it locked. Slide the lock button on top of the player so that you cannot see the orange spot.
Aug 03, 2008 | SanDisk Sansa MP3 Player
Can't access on the computer and doesn't turn on when disconnected
I downloaded and reinstalled the latest version of media player form windows. problem solved. thanks anyway.
Jul 25, 2008 | SanDisk Sansa MP3 Player
Reset should work
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 13, 2008 | SanDisk Sansa m240 MP3 Player
MP3 turns on but shuts off at the sandisk logo
The battery is dead. Leave it connected while the computer is on for about 3 hours and if the battery is still good that will charge it.
Jan 16, 2008 | SanDisk SDMX1-1024-E18 MP3 Player
How to remove write protect on my usb flash drive
Make sure your mp3 "HOLD" option is not on!
Its really as simple as that. The hold button 'protects' the files.
Nov 24, 2007 | MP3 & Digital Media Players
Sandick 1Gb MP3 Palyer
For Sansa or Sandisk problems, contact This site is dedicated to Sandisk products and can help you. Good Luck
Jun 20, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
733 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
