Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Knocked over my seagate 500 gb hard drive. makes a beep noise and will not connect to computer
  • 30 Answers
You say its beeping? like an error code sequence? i would search the intnet for seagate error codes and try to match the code with the problem. or call tech support.
Posted on Jul 23, 2009
My seagate 1 tb dropped off my table and now its making a beeping noise. i tried changing ports and unplugging it but it still wont go. help?
if it is dropped, there is a possiblity that the Hard drive lens may be damaged. Kindly consult your local pc provider for immediate repair..
Sep 03, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hello, my seagate external drive is not registering on my mac but is making a beeping noise. What does this mean?
Try changing your USB cable you are using to connect the External drive.. It may be that the usb cable is not good and thus the Drive is making beeping sound..
If it helped you please say thanks and like/rate the comment please
Jun 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My drive was working fine the next day i pluged it in and it just wasent appearing on my desktop is was just making a beep beep beep noise :( please help
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive
good luck
Sep 16, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Oct 04, 2009 | Seagate Computers & Internet
Seagate,external, Hard drive,160GB,knocked over,doesnt work
Buy a new drive. The beeps are coming from the hard drive and they say I'm broken. If you need to recover data, and only if you need it like life and death because it will cost a bit, send it to a data recovery company. I would search on line and look for somebody local to you for this if you need it.
As for your old drive, if you like to tinker, you may be able to remove the drive from the case and replace it with a similar sized drive with a matching interface (ide or sata). I personally like to remove the rare earth magnets from bad drives to make refrigerator magnets and toss the aluminum housing into the metal recycling barrel. It also ensure personal data is never coming off those platters.
Aug 09, 2009 | Seagate Momentus 5400.2 120 GB Hard Drive
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I knocked over seagate 500 freeagent and it beeped and groaned and nowcannot be accessed, orange light works but does not register on mycompter. What to do?
is damaged my friend. Hard drives are very, very delicate pieces of equipment. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I'm not expert but try freeze therapy. I did it in on mine and it did not work but I hear it does rarely. Basically all you do is wrap the harddrive in a plastic bag tightly to prevent any form of moister entering, leave it in for about two days and plug it back it. It's said that sometimes if the lense is shaken out of place the cold would make the metal go back to original placing. This means you plug the harddrive in while still frozen, just something try before throwing it away or replacing it.
My freeagentpro 1TB was accidently knocked over when backing up. Now the computer doesn't recognise it, and the hard drive makes a strange noise.
IM SORRY MAN BUT UR HDD HAS MESSED UP IF U HAVE THE WARANTEE SEND IT IN AND THEY WILL REPLACE IT WITH NEW ONE. IT HAPPENED TO ME TOO DESAPOINTED
Jun 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,714 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
