205 and 210 mm blades are the modern equivalent of the 8" blade. I too wanted a finer cut blade in my mitre saw. I had stock of a couple of 8 inch blades but when trying to fit them I found a 205 went in but a 210 wouldn't. I preferred the 210 so I had to modify the guard a little.
As your blade is already 210 mm you probably won't have any problems with an 8 inch blade or either of the metric equivalents, though it is unlikely a larger blade will fit, if you can find one. The blade designed for cutting laminate provides just about the finest cut.
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
