Question about Dell Inspiron 8000 Notebook
Compaq Laptop cannot turn on...
My compaq laptop won't turn on and the two battery and powerlights does not lights? I've tried to turn it on by using different adapter but it still cannot on? My laptop is compaq presario v3000.
  • dx_girlz02 Jul 22, 2009
    thx for ur advise. For ur info, i used the same voltage and amp adapter. i've tried resetting the laptop...but it still fails to turn on.
  • 42 Answers
Are your batteries emtpy? Maybe your adapter is broke?
Did you try using the adapter, after disconnecting your batteries?
Posted on Jul 22, 2009
  • Edwin Broertjes Jul 22, 2009
    Did you try pressing the power-on button for about 5 seconds?
Comprq presario cq40 laptop con't on on button light is flash
Posted on Jan 05, 2013
  • 23 Answers
If I remember correctly,the v3000 series was part of the recall for the nVidia video cards. does it by chance have a nVidia geforce go 6xxx,7xxx,or 8xxx series video card?
Posted on Mar 03, 2010
  • 696 Answers
Hi DX,
was the adapter you tried the same voltage and amperage(listed on the bottom as V and Amp, usually 19V, 3.42Amp or something similar). If it was not, don't ever plug it into that laptop again...it can cause a lot of damage if they don't match.
Assuming they were the same, that means the adapter is not, or at least not the only problem. Try reseting the laptop, remove the power supply and the battery, then hold the power button down for 60 seconds. Once you've done that, plug the power in again and try turning it on.
If it fires up, wait for it to finish and then shut it down and put the battery back in, then try again. If it's still working your done, if it fails your battery is the problem.
If it doesn't work on the first try the problem is either in the charging circuitry or worse. If that's the case you will need to take it to a qualified shop, or depending on price of the repair, replace it.
Chris
  • 696 Answers
Ok,
Given that information and assuming the other adapter is good, it sounds like a dead short in the laptop. If you're lucky it's either in the power button($50-80 to fix) or it's in the AC plug($100-200 to fix) If it's on the motherboard repairs could be $500 or more and may not be worth doing.
I would take it into your nearest HP repair center or Call 1-800-hp-invent and ask first if it's under warranty, second if it may be under recall and if not, do they have a flat rate repair option available for that model. Once you have that info in hand you can decide if it's worth repairing or not.
If you choose not to deal with HP directly, provide me with you Country, State/Prov and City and I will point you to a nearby facility that can help with the hardware repair.
Chris
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: Can this HP Pavilion DV9000 laptop adapter fit for
The pins appear to be the same size, I have used these adapters for some time, Most of the "V" series and "DV" series share the same power adapters. In fact the adapters are the same voltages, which is 18.5-19.5 volts.
Posted on Jan 15, 2010
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Nov 13, 2012 | HP Compaq nc6000 Notebook
Compaq presario v6317 not turning on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 04, 2012 | Compaq Presario Computers & Internet
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
I have a problem with either the battery or my charger on my laptop compaq presario 1692. i would like to know which one of them is the problem?
Remove the battery from the laptop
Connect the charger and turn on the computer
If you have a bad battery, your computer will turn on
If you have a bad charger, your computer won't turn on
Jul 24, 2011 | Compaq Computers & Internet
Computer freezes right after start up
Try to turn off the laptop. Remove the cables and battery on it , press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn it on, then check if the pc freezes up. If it is, check if your keyboard has lights on it. If there is no lights, need to call compaq to replace the motherboard. If keyboard has lights and you dont know how to remove the parts inside your laptop, you still call compaq to replace the power supply or the video card of your laptop.
Aug 11, 2010 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron 8000 Notebook Logo
2,074 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
