Question about Compaq Presario 5000 PC Desktop
How to take drives in and out, they seem to be spring held instead of screws.
  • 42 Answers
These springs are in different variations. But most of the times, just press the spring (sometimes only on one side of the disk) and slide the disk out (or in).
This is the great advantage of these springs, you don't need a screwdriver any more.
Precautions: Turn of the pc and disconnect power.
Posted on Jul 22, 2009
How do you install the belt on clothes dryer
usually goes in a 'Z' type shape. around drum to around motor drive, then push spring loaded wheel towards motor drive and hook belt over that for tension. of course this is all done by feel for the most part because you cannot see well while trying to put it on. good luck
Mar 15, 2015 | Dryers
Spring came out
Possibly but it may well be more cost efficient to replace the DVD drive. Only held in with one screw.
Jan 15, 2014 | HP Pavilion Computers & Internet
How to remove hard drive from HP Pavilion a1243w
Hard drives in towers are easy to replace. Once you've opened the cabinet, the drive is held in place with screws or clips. If it's clips, you may just have to spring the front off to slide it out forwards, put the screws into the new drive and slide it back in otherwise just undo the screws, slide it out into the cabinet taking care not to pull any other plugs out then slide and fix the new one into place.
Of course, it's no use doing this if you don't have the recovery discs or a windows disc to re-install the operating system.
Feb 25, 2013 | Computers & Internet
When the weather is hot and humid, our sub-zero seems to barely work. Freezer works fine, but the upper part is a joke.
the leading thing causing that is a dusty condenser coil. to clean that remove the grill above the refrig, and the white painted plate behind that and vacuum the coil on right side ,typically the grill is held on by springs and a either 1 screw in the center or 2 screws on the corners of the rim above the door,remove grill by opening refrig. door and remove screw tilt grill down and disattact springs
Good luck, i hope this helps
Gene
Jul 31, 2011 | Sub-Zero 650 / O Bottom Freezer...
Where does the spring go on a tc2 model 8900 ice auger, we removed and replaced the carb and there is a small spring that looks like it attachest to the carb but where
it should be installed over the jet set screw, located near the bottom of the carberateur, or it might be the idle set screw, located on the side near the top, close to where the cable operates the throttle. This screw is usually held tightly by a spring, more so than the first place I mentioned, and after thinking about it, the jets are not held in place with a spring... with out pics and a model, it is almost impossible to really tell. I am just giving yo an educated gues... hopefully this is it.
Don't forget to rate the answer.
Jan 25, 2011 | Garden
The fusing unit on my konica minolta c250 seems to be loose and on further inspection one of the springs holding it in place has come off.. it is still held in place but may not be tight enough. Is this...
The fusing unit on the C250 is not held in with springs. There is a silver colored screw on each side towards the bottom of the fuser that holds it in. You might be talking about another part of the copier or an assembly attached to the fuser but not the fuser itself. Maybe a bit more detail would help so we can assist you further.
Thank You for using Fixya.
Jan 19, 2011 | Konica Minolta bizhub C250 All-In-One...
I have the sameproblem
this is a snubber problem your tub in held straight by 3 springs they go from the washer frame to the bottom of the tub one spring is unhooked; bet it was held by the screw
Sep 07, 2009 | Whirlpool LTE6234D Top Load Stacked...
How to you remove the dvd drive on a hp compaq nc6320
It will be held in place by a single screw. This can either be on the bottom of the machine just behind the drive (towards the center of the base) or under the keyboard.
Once the screw is undone, turn the laptop on, hit eject on the drive so it pops open, turn off the laptop and fully extend the tray - once the screw is removed it should slide nicely out.
Jul 29, 2009 | HP Compaq nc6320 Notebook
My wife's mother had an old New Home Sewing machine. Instead of a belt drive off the motor this machine has a slip on rubber wheel about an inch in diameter that is spring loaded and presses against the...
I have these in stock. you'll need to give me the diameter of the rubber wheel as there are three different sizes. These run $5 +s/h. Stepping Stones Quilts
912-638-7128
Jun 11, 2009 | New Home L-373 Mechanical Sewing Machine
Removing current cd/dvd burner from tower to replace with new one can't seem to get it out.acer tower, not real smart with computers sorry
most CDRW drives are secured using 4 screws (2 on each side) which means you have to remove both side plates of the tower to remove the drive, sometimes manufacturers use rails which "clip" the drive in place and are removed via the front instead (sometimes having to remove a retaining screw).
after that the drive is only held in place by the connected cables.
Sep 22, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
