Question about Plantronics DSP-400 Headset
Mute Button Stuck, red light won't go out when pressed.
The mute button always comes on when I start up my computer. So I click it off, no problem. But now, it seems to stay on. I suspect I might have on this last occasion pressed too hard. Of course I'm looking for a fix on this?
4 Suggested Answers
Peter Denton
  • 16 Answers
SOURCE: No speaking ability
The mute button on these is the little black button on top of the earpiece. It will only be on if you turn it on during a call. If you turn the headset off, the mute button goes off as well.
Check the compaibility 'wheel' on the side of the base station. The most common setting is 1 but some phones use 2,3 & 4. Just try it on each setting until it works. Other than that, check the microphone volume adjust setting underneath the base (ABCD switch) and see if changing that makes a difference. Of course there is always a small chance that the microphone is dead.
Posted on Nov 05, 2008
SOURCE: My 925 is stuck in
I need a bluetooth headset with 30' range and a simple mute button... no "hold for 3 seconds" or "combo" keystrokes.
Posted on Jan 08, 2011
wb91
  • 126 Answers
SOURCE: My Plantronics Voyager 520 seems
Try deleting the headset out of your phone and then re-pair it back up and see if that corrects the problem.
How to Pair the Plantronics 520 Headset
Good Luck from Headsets Direct!
Posted on Jun 28, 2011
Mute button on probook 6450b
sounds to me like the indicator light is stuck in the on could be something touching the wires and causing a bad connections
Nov 06, 2013 | HEWLETT-PACKARD ProBook 6450b Notebook
ProBook 6450b mute button on keyboard is always orange
Is the volume muted or not when the light is orange? If it is muted then use the icon on task bar and increase the volume, to see if color changes. If it is not muted and a change of volume does not affect the color of the light, maybe that is the normal color for it. Did you read the manual and find that orange means trouble. On my computer, the light for my WifI is always orange.
The speakers may be muted by an Fn +Fx key sequence, or some additional buttons on the computer.
How to mute microphone on Siemens 5020
Locate the mute button on the button pad or headpiece or open the "Options" menu and locate mute from there.
  • Press the mute button or select it from the "Options" menu and click on it.
  • Press the mute button again to deselect mute. You will have to open the "Options" menu to deselect mute on micphone headset that mute in this way.
  • Apr 11, 2012 | Lands Phones
    HP probook 4420s stuck on mute
    Look on you system at the keyboard and you will find a key that toggles the mute if he pressed it. It will toggle between on and off. Normally the mute key or button will look like a megaphone and if it is muted it will have an x over it. Press it to unmute it. Sometimes if it is a key, you might have to press the FN, CTRL or ALT key while you press and hold the key that toggles the mute.
    Another way to remove the mute is to Double Click on the megaphone if you see it at the bottom right near the time. This will bring up the volume control and you just remove the check mark from any that is muted.
    Also you can click Start/Control Panel look for volume controls that might be muted and remove the check mark on mute.
    Also click Start/Programs/Accessories/Entertainment/Volume Control and remove the check mark on muted items.
    Apr 07, 2012 | HEWLETT-PACKARD HP ProBook 4420s XT940UT...
    My acer netbook is stuck on mute
    if the little x over the volume bar is still stuck after moving it up you may have to hit the function key (fn) on your laptop and hit one of the F1-F12 KEYS that look like a mute or volume symbol also there should be a mute button on the laptop itself. if all that fails. go to (xp) right click on my computer -device manager-and see if you have a red or yellow x over your sound sound devices (win vista or 7) go to computer, sys prop on the top then device manager. if you see any of htose yellow or red warnings you will need to re-download the audio drivers from acer website Let me know if this helped.
    -Brian
    Mar 19, 2011 | Acer Aspire One PC Notebook
    I cant unlock my phone anymore.after i upgrade the software i lock my phone and after that it wont unlock .message shows click or press mute button to unlock. i just got my phone a week ago
    Hi, you have to press the play button on the top of your device.
    the button that has a red encircled is the mute button.
    everytime you lock your keypad, you have to press that mute button to unlock it
    hope that helps
    Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
    My radio is stuck on mute. How do I turn the mute
    Where is the mute button on an RFX9500?
    May 04, 2010 | Phase Linear UCD200
    How do i turn off the sound
    You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
    (fn key + Mute symbol key)
    I hope this is helpful to you.
    Thanks
    Apr 26, 2010 | Dell Inspiron 2200 Notebook
    Just got the CD445 Base Station. Red light keeps blinking
    press the cid button then press menu then scroll through your missed calls then hit exit
    Dec 26, 2008 | Philips ACCESSORIES & S60202 Earbud/Line...
    Philips universal remote codes for symphonics tv
    Manually turn on the device you want to control
    1. press and hold the CODE SEARCH button til the light stays on release the code search button
    2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
    3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
    (the red light will blink off after each time the channel up button is pressed )
    4 Press the MUTE button to set the code
    hope this helps
    Nov 23, 2007 | Televison & Video
    Plantronics DSP-400 Headset Logo
    472 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    skiffy99
    skiffy99
    Level 1 Expert
    shaun taylor
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
