NEED TO ADD 18 MORE CAMERAS - Computers & Internet
  • 198 Answers
This helps no one.
Fill us in and we can help you better.
Thank you.
Posted on Jul 22, 2009
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nov 15, 2015 | Nikon COOLPIX L100 Digital Camera
Where and how to register my camera
Point your web browser at http://www.canon.com/ then pick your country or region of the world then go from there.
If you require further assistance, please add a comment to this question and specify where in the world you are.
Sep 30, 2014 | Cameras
What to numbers can you multiply to get 280 and add to get-18?
When you say "to numbers" I assume you meant "two numbers."
There is no solution.
For the product of two numbers to be 280, either both numbers must be positive or both numbers must be negative. For the sum of two numbers to be -18, one or both numbers must be negative. Taken together, both numbers must be negative.
We can find two numbers that multiply to 280 and add to +18, then simply take the negative of both numbers.
The square root of 280 is about 16.7. The sum of any two numbers that multiply to 280 must be at least twice that, or at least 33.4. Since 33.4 is greater than 18, there is no solution.
If you want to do it the hard way, take any pair of negative numbers that multiply together to 280, add them together, and see how close you come to -18. For example, -1 and -280 add to -281. -2 and -140 add to -142. -4 and -70 add to -74. -5 and -56 add to -61. -7 and -40 add to -47. -8 and -35 add to -43. -10 and -28 add to -38. -14 and -20 add to -34, which is as close as you can come in the integers.
Jun 25, 2014 | Office Equipment & Supplies
I own a photography studio and need to buy bayonet mount rings for all my students' cameras. Where can I buy them in bulk?
Well, I have never needed to purchase my bayonet rings in bulk before; however there is a great website that should have just what you are looking for. I will post the link for you here - hope it helps.
http://www.alibaba.com/showroom/bayonet-adapter-ring.html
Jul 18, 2012 | Nikon 18-55 18-105 18-135 55-200 Bayonet
5/6+11/9= ?
What a strange question for digital cameras... anyway, you have to make them both 18ths.
5/6 is 15/18
11/9 is 22/18
Now you can add them together to get 37/18
37 is a prime number, so you can't simplify it, so 37/18 is your answer.
Otherwise known as 2 1/18 (two and an eighteenth, or 2.055 556)
Feb 04, 2011 | Cameras
Can I add a watermark to a flyer using Printmaster Gold 18?
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
May 20, 2010 | Broderbund PrintMaster Gold Version 18
I have the Simon 3 security system with one motion detector installed. I didn't set this system up but would like to add another motion detector and was wondering how hard this is to program it into the...
I don't of any system that is simpler to add a device to. The process is in the manual and is something like press "add" on the panel, follow some prompts and press a button on the rear of the motion sensor. Pretty easy if you dont have keypad phobia. Electronic version of the manual is at this location (adding a sensor starts on page 18).
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
I took 18 pictures and the display is saying FEE I cannot take anymore pictures what does this mean?
Need more information..
.. memory capacity, internal and/or expansion (cards), file size/resolution of the pictures....
I would suggest that the memory is full, and the solution is to transfer the 18 photos to your computer and clear out the memory, or add more memory.
If you have an expansion card installed, maybe you need to tell the camera where to store the photos.
Oct 30, 2009 | Cameras
How can i print date samp in photoz..without using 4x6 photo in my canon poer shot 100s camera..
you can do that if you're doing direct printing (camera to printer) using the caera transfer settings, or if you want to save them to your omputer, you need to download the photos using the EOS utility (comes with the camera) and add the [date & time] stamp from the software settings
May 08, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Nikon D 40 flash pops up but does not flash.
Is the flash on Off mode? Is the battery fully charged? If not, charge the battery and try again.
Dec 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
