Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
Dvd combo not detect dvd's
My dvd combo work properly work with cd but it does not detect dvd's
    Sergeant:
  • 173 Answers
Your Lense has some issue.
You can clean your lense with disk cleaner disk.
Pur chase it from nearest shop it is called "Lense cleaner disk"
then put it into combo drive then play it then it clean your lense then check .
If still not access your dvd then if it is in warrenty go to service shop they replaced it.
And if it is not in warrenty then you should need to repair your lense or purchase new lense.
Thanks
Posted on Jul 22, 2009
I have a Samnsung SM-352N DVD CDRW Combo drive. But recently the drivers have got corrupted and I am unable to get back my DVD combo drive to work. In the Device Manager, the DVD CD RW drive is shown with...
control panel admistrive tools,computer management,device manager scroll down cd/dvd drives you should see a yellow question mark? right click to reinstall drivers or right click select enable or properties then general to troubleshoot or region select 4 you might uninstall reboot then reinstall
hope this helps
Oct 02, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My pc is not detecting combo drive
Hi
STEP 1:Please check for the power and IDEcables (both ends on the IDE) whether it is connected proper or not
STEP 2:Please check for the viruses in the computer.
STEP 3:Try with a different computer and check whether it is deducted or not.If not in the sense it is the issue with the Combo drive
Sep 26, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
My DVD player can't detect DVD CD file, but it can play CD. i've tried to check on the device manager and its working properly. i also have tried reinstalling its driver but still not working... i am using...
i have faced this problem in my case DVD was working and cd not you problem is the lens of you cd/dvd drive has become worst and cant work any longer it needs to be replaced. Hopefully it might have helped you.
Jun 19, 2010 | Microsoft Windows XP Professional
My new hardware might not work properly(no detection)
ok
if your storage device not wortking properly.
Go to device manager and uninstall usb drivers from computer then install again.
May 28, 2009 | Mass Multimedia Apricorn Mass Storage...
DVD/CD DRIVE NOT WORKING
Check the cables if they are connected properly and see if the cd/dvd rom is first detected in bios..
Jan 28, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Samsung CDRW/DVD SM-352F
First i need you to make sure that both the BIOS and the WINDOWS is detecting your drive as 'combo' drive. If not, your drive is not combo, it is CD drive only.
Because both rely on the product ID that is built into the Drive.
If u are confirmed of the fact that your drive is COMBO, then the problem might be with the laser.
Combo drives use separate laser beams for DVD and CD operations, and
it's possible for one (either one) to fail while the other is still
working. But it's more common for the DVD to fail while the CD still works.
You need to contact the service center with your drive ,if that is the case.
Hope my info is useful.
Bye....
Sep 18, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
CD Burner not detected.
Check your different jumper settings in the drive; Is your CD RW drive set in the proper setup as a slave or master drive; or as a single drive.Check in your bios, in the disk management section if your CD RW is detected.
Apr 22, 2008 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
HP CD-RW DVD RW COMBO
I HAVE AN HP LAPTOPmag-glass_10x10.gif WITH CD-RW AND DVD RW ON IT BUT WHEN I TRY TO BURN EITHER OF THE TWO IT SAYS DRIVE NOT DETECTED. HOW CAN I MAKE SURE IT IS INSTALLED PROPERLY
Apr 01, 2008 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
Not detecting
Dear dhavu,
me too have the same problem with samsung dvd combo drive.. no medicine fo it....
Jan 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
DVD R not working properly
So it won't play movies most of the time? Time to replace the drive more than likely. When a laser gets weak, sometimes it wont read the DVD's, but will read regular cd's without problems. Eventually it won't read anything. The laser requires more power to read a dvd than a regular cd. The laser itself it adjustable, doesn't always work, but it's a sure sign that its on its way out. They are cheap to replace these days. :)
Oct 24, 2007 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
220 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
