Grundig Vision 26 has vertical fussy lines taking up 1/4 screen
Seems to occur once the TV warms up - maybe once running for 1 and 1/2 hours.
Consists of a block of vertical lines taking up 1/4 of screen and 1/3 of the way across.
any one seen this before?
  • 188 Answers
LCD panel faulty.You can try to resolder the LVDS panel and place a cooling block on the flatpack IC.
Posted on Jul 22, 2009
How do I tune a Grundig TV/DVD with no remote? Is it a combination of buttons on the front panel? Thanks
Get a pen and a piece of paper.
If I remember correctly, each button has a bizarre symbol next to it.
Draw the buttons on the paper and draw the symbol that appears beside each button.
With the TV on, press the first button and note what it does. Press it a second time to see if that progresses to something further or cancels the operation.
Repeat this for the other buttons.
I seem to remember a vertical green line appearing on Grundig sets which indicated that the tuning was activated. Look for buttons such as > or >> or < or << that suggest scanning for channels. Make sure you can pick up analogue TV signals in your area.
It also helps if you have a VCR or DVD recorder which is already tuned and you can tune the TV to that signal.
Jan 06, 2015 | Grundig 15 in. LCD TV/DVD Combo
Grundig lcd tv has vertical purple lines that fade after a few minutes
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Grundig Televison & Video
White Line Across Television
If it is just a collapsed picture and view as a white horizontal line across your screen. Loose vertical IC connection or is start ailing. Best is to reflux its pin with a new lead or resolder it.
But I don't recommend you do it yourself if you don't have experience doing it.
Nasty voltages may caught you.
Apr 07, 2009 | Mitsubishi CS-35405 TV
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
One verticle line appeared
Same thing happpened to us with a Vizio 26" TV. Its a defective panel,and cannont be fixed, we were told. Vizio replaced the TV under warranty.
Nov 22, 2008 | Olevia LT27HVX 27 in. LCD Television
Vertical lines problem
On your blue tube there is a crt broad that may have a bad capacitor 4.7uf 250 volts most likely it can be leaky not able to hold correct charge also it might have video ic on same broard breaking down, this will cause your problem unplug crt broad from bottom neck of tube turn set on see if problem goes away if so then it means you have problem with crt broad or it could be your tube.Hope this helps you out!
Jan 18, 2008 | JVC HD-52Z575 52" Rear Projection...
Only Horizontal line
If you can hit it, it is probabl;y just bad solder joints on the vertilcal output IC (yes thats right vertical, because it stretches,or in your case compresses the picture vertically). kind of hard to point you to it if you've never been in a tv but it will be a little chip standing up mounted onto a piece of metal (heat sinc). There will be a few though the IC will likely have 1 row of pins maybe 7-10. And probably have a part number on it that begins with "LA" like maybe LA7838. You can tap around the different heat syncs with a NON-METALIC with the TV on until you find the one that is sensitive that should help you identify the vertical IC. Any way unplu flip the PCB over and resolder that IC. That should take care of it.
Dec 28, 2007 | Televison & Video
LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Vertical Red Lines
IS IT AN LCD ? IF SO IT MAYBE THE CONNECTOR ON THE LCD PANEL THET USUALLY GO DRY JOINTED
Oct 08, 2007 | Akai PDP-4216M 42 in. Plasma Television
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Electro Med Services...
