Question about Philips Phillips 16X External DVD 2XRW (609585116023) Burner
I cant get on demand sometimes
Its always stalling and keeps saying error and we called comast so many times and when they fix it it only stay working until the next day what should i do?
    President:
  • 2,559 Answers
Call them and demand they fix it right and credit your account for all the time it hasn't worked
Posted on Jul 22, 2009
STARTS BUT WON'T STAY RUNNING
Could be something as simple as a dirty fuel filter.
Get a can of quick start at the store and have someone start it up, when it wants to die squirt a shot into the intake ... if it runs again for a bit you have a fuel delivery issue. Check the fuel pressure to see if the pump is functioning properly.
Mar 18, 2015 | 1997 Jeep Grand
Gauges dont work and stalls while driving
Although your question is unclear, I think you are trying to say that the vehicle is stalling out, and that you have an error on the dashboard display saying "NOBUS."
The "NOBUS" error means that the dashboard display is not receiving data from the main computer.
First, check that your GROUND BUS CABLE and GROUND STRAP are in good condition and making good contact. If the grounding is good, your main computer has failed, or the main computer connection is loose or dirty. ALSO, CHECK TO BE SURE THAT YOUR MAIN COMPUTER MODULE HAS GOOD GROUND.
Jul 25, 2014 | 1999 Dodge Durango
Jeep 96 dies sometime going down the road and wont start sometimes. will start after 10 miles at times and 24 hrs sometimes. the dash says check gauges. help woman alone need advice
Fuel pump intermittent, check for fuel pressure before dropping the tank to renew pump.
Otherwise check electrical connection at battery, and make sure you do not have an open circuit.
Loss of connectivity could cause this issue, failed fuel pump sometimes work, but are not reliable.
You should see 30-45 psi at fuel rail, and the regulator should bump pressure 5 psi when reving the motor. Higher pressure indicates failed regulator.
Jun 23, 2014 | 1996 Jeep Grand Cherokee
LG model LDS5811WW/02 has never cleaned the dishes since first installation. Put clean dishes in and they will come out dirty too! Have tried all dishwasher soap types and brands and drying agents. Always...
if the soap/detergent isn't completely rinsing out of dispenser, it sounds like water isn't directed the top spray-arm. possible a defective vario motor; as it directs water to the water channel that supplies water to the middle and upper spray arms.
Jul 03, 2010 | LG LDF8812 Stainless Steel Built-in...
I have a fuji A100 10.0 megapixil digital camera. am getting zoom error message and cant get camera to do anything..can you help
Owners manual says "zoom error" indicates a camera malfunction. But, try this, gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur.
Also, sometimes you may have to try several times until you finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Mar 19, 2010 | Fujitsu Cameras
Whenever i try to do the latest update for cod5 (ps3) i always get an error sometimes i odnt even get 1% and the miutes can go up to 250+ other times i get fast time but an error occurs the highest i ever...
well i finished it and it worked but after i finish a match the screen would go black and sometimes when i try to start it it says error i think its courrupted data the only way to fix that is to restore your playstaion and redownload any map packs (if you had any)
Jul 18, 2009 | Dmm Call of Duty: World at War
When accelerating there is no power but when releasing accelerator slowly power picks up. why is this happening 2001 ml270 cdi
Hi, this is a common symptom of a clogged fuel filter that is straining the fuel pump itself.
When you accelerate, this initiates a rapid fuel flow through the lines. if the filter cant pass the proper amount, its will stall or hesitate the engine and cause sputtering or loss of power. due to this clogged filter, the pump cant keep up with your acceleration demands at this time. the reason for the power pick up upon De acceleration, is because the lower amount of fuel is able to pass through quite easily but, as soon as you demand more power, the clog will obstruct the more intense flow of fuel to the injectors.
Simply replacing the fuel filter and pump will fix this issue.
Please rate and god bless:)
Apr 17, 2009 | 1998 Mercedes-Benz C-Class
1991 geo storm stalling at idle
maybe try replaceing the ingnition modual. that part can do a lot of weird things to these cars. its located inside the distributor cap, really easy to do. about $40 and 10 mins or less. sometimes as they start to fail they do odd things sometimes but not always
Mar 13, 2009 | 1991 Geo Storm
1997 Jeep Grand Cherokee Stalling
Best thing to check is your fuel filter. After sitting for a little while, it will allow fuel through it but when you put a demand on the system, it cant supply enough and will sputter and die. Its easy to replace and very inexpensive. If it continues after that, you will at least know it was eliminated and can move from there.
Aug 22, 2008 | 1997 Jeep Grand Cherokee
Philips Phillips 16X External DVD 2XRW (609585116023) Burner Logo
51 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
