Question about Mitsubishi WT-46809 46" Rear Projection Television
TV won't turn on!
My Mitsubishi WS-65819 set was arching for about 6 months now and I went out of town for about a month and now I turn on the set and the green light comes on and then shuts off after about 2 seconds. the picture never comes on? what could this be?
  • 668 Answers
If it was arching, It could be the HV Transformer, or the High Voltage Block. It could also be that there is a High Voltage Leak at a Anode Cap on one of the CRTs. Because of the arching issue, I would call a Mitsubishi Professional to diagnose it. If you need help in locating one, call Mitsubishi at 1800-332-2119 and they could help you find one local to you.
I hope this helps,
Skyassoc
Posted on Jul 25, 2009
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
Mar 28, 2013 | Mitsubishi WS-65819 TV
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Ws-65819 Upside blue arch extending from top of TV screen
Used your info to isolate and verify trouble with the upside blue arch. It was a convergence trouble. Then hired tech from your site recommendation to come out and fix today. He replaced both convergence chips and cleaned electronics. Works like new. Thanks for your help but you should allow customers a one time view-to-trouble search that I think would build a you a solid following. Folks would recognize your site as good source to search when trouble strikes and be more likely to subscribe. It gave me a good sounding benchmark but it could be enhanced. Thanks!
David Herrera
Jul 14, 2008 | Mitsubishi WS-65819 TV
3 colors on TV
It sounds like we had the same problem. Our TV is the same make and model also about 6 yrs. I went to the Mitsubishi website and was able to find a service company in my area. It turned out to be the convergence amplifier. In the end we replaced a pair of convergence amplifiers and he also soldered the pins. (in home) The cost of the repair was $375, much less than purchasing a new TV. I realize I was no help in locating the amplifiers for you but maybe if you call a service company in your area they can help you with their location inside. Hope I was of some help.
Mar 22, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Problem
it the circut board that is connected to the power cord ,
Nov 26, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
