Question about Microsoft Xbox Console
Red ring....sometimes Sometimes the xbox will work but while you are playing a game, the disc drive opens up. Then if you try to start it again, I get the red/green flashing light........
    President:
  • 2,559 Answers
The hard drive is overheating
Posted on Jul 22, 2009
  • Microsoft Master
  • 3,866 Answers
Something has overheated in the unit causeing the red ring. I would if I where you is to clean it out and try to start it again.
If that does not help the best bet would to call sony for rapair at this point.
But if it still works and you want to keep playing with it like that its all fine and good but i am sure its not going to last you long.
Xbox wont read discs
You will need to have the drive replaced. We can do it for you. We are a listed repair service on this site.
www.videogamerepairservice.com
Dec 17, 2012 | Microsoft Xbox 360 Console
Sometimes it opens and sometimes it dont , sometimes it plays discs and sometimes it dont turned it on and had the red rings of death turned it off then on and they were gone some times the fan dont start...
This is called Red Ring of Death or RROD by the community, it means that the CPU or GPU or both have a bad solder joint, that is caused from rapid heating and cooling from poor cooling design of the xbox 360. To fix it is pretty simple. Follow these instructions to take apart your 360: http://www.rrodfix.com/how-to-take-apart-the-microsoft-xbox-360-game-console.html Stop once you've removed the dvd drive. Now Remove the fans from the back, and set them on the heatsink on the right the flat one, and make sure they are pointing where the air is going up. Put a peice of of carboard or plastic something non conductive in between the heatsinks to prevent airflow from the fans. Turn on the 360, and leave it til it goes from 3 rings to 2 rings, wait 3 minutes, then switch the fan over to the other side. Wait about as long as you did for the other one then turn off the 360. Wait 1 hour for the 360 to cool off. DO NOT move the 360 while it is cooling down durning this period or you will permantly ruin it, the solder is being reflowed. After an hour, put the fans back, and turn the 360 on, it should work. Once its working, I recommend doing a 12 volt mod on the fans to prevent RROD from happening again, and changing out the thermal paste with artic silver 5. As for reading discs, open up the drive air it out, but not the laser, use a qtip and some rubbing alchol, clean it off and put it back together. Fans all you can do is replace them which I recommend just buying off of ebay or llamma.com
Sep 16, 2011 | Microsoft Xbox 360 Console
I got 4 ring the other day and now when i go to play my games it will load the game and i can start playing then it will say cd not readable no matter where i go from the menu and my cds are perfect and...
Four red rings means there is a malfunction with your AV cables, usually it happens when they're not plugged in all the way. So it should have nothing to do with it. Unfortunately your CD/DVD drive may be starting to go. If it doesn't read disc then try ejecting and loading again. if that doesn't work you will probably need your Drive replaced. Feel free to contact me if it comes to this.
Jan 17, 2010 | Microsoft Xbox 360 Console
Resident Evil 5 freezing and red ring of death
Ok well the only thing i can suggest is install the game to the hard drive and play it from there .
This worked for need for speed on my 360 which was giving me a similar problem
Apr 24, 2009 | Microsoft Xbox 360 Console
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 dosent READ AND ROTATE WELL! PLZ HELP ME!
you will need to take this apart, and look inside the disc drive itself, and most likely tights some screws up as they get loose with the vibrations of the drive
Feb 16, 2009 | Microsoft Xbox 360 Console
Doesnt read my discs
This happens to me sometimes as well, but usually it's very infrequent, and happens mostly with old original xbox games.
Basically, the xbox is just temporarily confused. Just eject and reinsert the disc and try again. Usually, the second try always worked for me. If that won't work, simply reboot the xbox with the disc in the drive. Now try to run the game.
Let us know if this works.
Ryan
Dec 31, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite - Will Not play games
Try to update the firmware of your xbox.
Jul 28, 2008 | Microsoft Xbox 360 Elite Console
Microsoft Xbox Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
