Question about Kenmore 24032\24036 Top Load Washer
How to fix a washer that leaks only when filling or draining
How to fiw a washer that leaks out the front when draining and filling
    Genius:
  • 1,122 Answers
Remove the 2 screws from the head console,flip it up,remove spring clip one on each side,pull cabinet toward you and off,now you can watch and see where the leak is-mike
Posted on Jul 22, 2009
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking underneath
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Maytag Neptune Leaking Water
pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
Dec 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
46 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
