Question about Samsung Refrigerators
How do I replace the Samsung RF266ABRS water filter?
  • Samsung Master
  • 3,372 Answers
How to Unlock Samsung Phone with a Broken Screen
Android Lock Screen Removal & Data Recovery is your best choice to remove locked screen on Samsung with broken screen.With its help,it's no longer be a problem to unlock Samsung broken screen without password.It can help Samsung users disable the password and pattern locked issues on Samsung device with just few steps.Applicable Samsung device including Samsung Galaxy S10/S9/S8/S7/S6/S5/S4,Note 9/8/7/6/5/4/3,etc,.
LEARN MORE
Broken Android Data Extraction How to Recover Data from Broken Samsung Galaxy A3 A5 A7 A8 A9 How to Recover Contact from Broken Samsung Galaxy A3 A5 A7 A8 A9 How to Recover SMS from Broken Samsung Galaxy A3 A5 A7 A8 A9 How to Recover Photo from Broken Samsung Galaxy A3 A5 A7 A8 A9
Posted on Jun 14, 2019
    Top Expert:
  • Samsung Master
  • 85,020 Answers
Posted on Jan 28, 2017
SOURCE:
Why would I be getting water build up to ice below the meat tray?
The unit self defrosts and this creates water. There is a drain tube that is supposed to let the water go to the bottom of the outside underneath. If that tube is plugged or damaged the water runs down the inside and creates ice.
Apr 25, 2015 | Samsung RF266ABRS Bottom Freezer...
I replaced the water filter and the light is still on. What should I do next.
Have you held down the reset button which is usally right on the front on the refrigirator. Please give your model to help you out more. I just have to hold down my filter icon and it disappeared.
Dec 14, 2014 | Samsung Refrigerators
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
KEEP GETTING 888 IN DISPLAY - HAVE UPLUGGED BUT WILL NOT RESET - HAPPENED BEFORE AT PRIOR TIMES AND UNPLUGGED AND IT DID RESET, BUT NOT THIS TIME
Hold both Power Freeze buttons for 8-10 seconds. You'll hear a chime when it resets and the correct numbers will show.
Jun 29, 2011 | Samsung RF266ABRS Bottom Freezer...
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
812 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
