Just installed a new motherboard. P5K Assus, 4gb Ram . It only boots as far as trying to load win and then it tells you to select, normal windonws, last know configuration, then it restarts again but it wont passes the loading of win and restarts. tried to start form cd drve with Win on it... no luck..
Comment by AFAR, posted on Nov 20, 2007
IT seems that my memory ram was not set to the right settings...I spoke to support and apparently my windows is now corrupted and will have to reinsta it again....
I have now set the right seting as we speak I am reinstalling Win XP.. how paintful!!!
Boot into the BIOS and look at the settings. Is the correct hard drive selected as the boot device? Are the IDE settings correct? Does it have an SATA or PATA hard drive?
When you change motherboards it's a good idea to write down the BIOS settings of the old board before you remove it. Probably too late for that now.
Rating Locked! (?) AFAR has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on System wont work with new Mptherbard:
