Question about Kenmore 42822 Front Load Washer
My front loader bounces all over the floor, crashing into everything
    President:
  • 2,976 Answers
The legs need to be leveled. Also, check the back legs for being off the pivot.
Posted on Jul 22, 2009
My bosch nexxt washer model wfmc3200uc/01 vibrates excessivelyrics and moves across the floor on spin. I have balanced and tried everything. Any advice on parts that can be replaced or where to start
This probably aint it, but my front loader did that, and it turned out to be a bracket that they install for transport. It connects to the tub and keeps it from bouncing while in transport. If it is connected, remove it and try it then.
Sep 06, 2015 | Bosch Washing Machines
My lg t655th will spin only slowly at the moment how do I get to look and see if there is anything stuck I have taken filters , everything else worksit is top loader d
go to the bottom of the machine nd check if u have a swoolen or crack on ur capacitor or ur floor level is in ballance
Jan 27, 2015 | LG Washing Machines
We are moving do we need to do anything special with the front loaders before moving.
it is recommend you put the shipping bolts that came with the unit back in. ideally you dont want the tub to be bounced around
Jun 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Jumping
On all front loader machines there are some transport bolts that fix the drum. Normally on the back of the machine, sometimes under the lid. Remove these bolts and the plastic "tubes" that they pass through and it will release the drum. To test if they are in still, open the door and put your hand in, then try to bounce the drum, if you can't then the bolts are still in. There are between 3 and 5 bolts and usually a cover with the instructions to tell you how many.
Apr 29, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating machine
have you check your floor..if floor is weak the hold area around unit will vibrate,,,easy test,,,stand in front of unit and bounce your body up and down things moving,,,weak floor,,cheapest fix..get a piece of pluss carpet and make 1 piece over all for legs,,when unit settles in thick carpet that will stop bouncing and noise
Dec 09, 2008 | Maytag MAH8700A Front Load Washer
The machine rocks so bad my wife had to turn it off
When I went to buy mine I asked about the bouncing and shaking and he said alot of times people do not take the nuts and bolts off the back that allows the drum to move properly causing it to move etc. There is a pic on the back that shows you were to remove them.
May 11, 2008 | Samsung WF337AA Front Load Washer
Coins in my front loader
remove element, remove coins with magnite telescopic type.replace element
Nov 06, 2007 | GE WSXH208A Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Kenmore 42822 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
