Question about Sharp ELECTRONICS - PRINT UXD1200SE UXD1200SE BROADBAND FAX DECT HANDSET INKJET 200SHE
Can you tell me where I can puerchase a sharp toner -product code 1983636? Thank you
  • 108 Answers
Try this product in ebay.in shopping online you can get it
Posted on Jul 22, 2009
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
I have copier in the name of Olivetu 16 cpm like sharp AR 5316, My machine toner finished so we are not available olivetty toner in this market, if i put sharp AR 5316 copier toner, then F2 signel is...
If that machine is not made by Sharp you can't interchange toners with other machines. On Sharps If you get a F2 code it means the toner ratio and sensors are not calibrated correctly probably due to the toner not being compatible. If it is compatible the sensor could be dirty and it needs to be calibrated again.
Mar 19, 2010 | Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp 5316 f2 problem
F2 If sub code is 02 that s toner supply problem .if sub code is 04 that is identification problem model error or data abnormality.do not forget to rate the solution.by MIAN JEE
Feb 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
How do i install a toner in my sharp m450n i cant work it out
You can go here: http://www.sharpusa.com/files/cop_man_ARM355_455N.pdf
Download the operation manual and on page 2-15 you will find the instruction with illustrations on how to add toner for that machine.
Hope that helps...
Lbcoaster
Jun 26, 2008 | Sharp Office Equipment & Supplies
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Sharp ELECTRONICS - PRINT UXD1200SE UXD1200SE BROADBAND FAX DECT HANDSET INKJET 200SHE Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
