SOURCE: i think my video card wont dump its cache
Have you tried un-installing and re-installing the game? EA has posted instructions for doing so on their support website. I've pasted the website link and instructions for doing so below. I've had to un-install and re-install at least six times myself, and have seen exactly the error that you have described occur twice. I hate this game for the crashes that occur regularly. My system plays Crysis fine, with no crashes, but crashes regularly from 2142. I wish that for once and for all EA would fix this game. It is the best battle simulation in the world, IMHO.
http://support.ea.com/cgi-bin/ea.cfg/php/enduser/std_alp.php?p_cv=2.719&p_pv=2.3040&p_prods=7%2C3040&p_cats=566%2C719&p_hidden_prods=&p_sid=CPOWU_Ti&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&prod_lvl1=7&prod_lvl2=3040&prod_lvl3=0&cat_lvl1=566&cat_lvl2=719&p_search_text=&p_new_search=1
Answer
Use the supplied Uninstall shortcut from the Start menu that came with Battlefield 2142 or use the Add or Remove Programs to remove the software. If you encounter difficulty in removing the game, carefully do so manually as follows:
To delete the configuration files and local copy of your account:
To delete the game files (in the default location):
To edit the registry and remove Battlefield 2142:
Battlefield 2142 should now be completely removed from your system.
SOURCE: When Someone Calls, I Go
this happens due to the firmware problem(this occurs due to virus attack) ....
try giving the restore factory settings(reset) in your phone ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
SOURCE: Not showing letest call(received,missed call,answered,dialed or all) history
I would try a master reset again and if that doesn't help. Try updating your phone's software with the Sony Ericsson update service....which is free.
SOURCE: acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
SOURCE: i have a game called flight unlimited 3 from
other than getting a version of xp put on to the system you cant do much
if you have a version of disk and product key and have plenty of rom and hdd space you can use virtual pc from http://www.microsoft.com/windows/virtual-pc/
its free software from microsoft its good software and it does'nt effect your computers original system ive had the same problem i have vista as well its a pain
hope this helps you
