Question about Canon PIXMA MP530 All-In-One InkJet Printer
Large black ink cartridge won't print
I've replaced the large black ink cartridge with 2 new cartridges and it won't print at all. I ran the deep cleaning but that has not helped. Any advice? Thanks.
    President:
  • Canon Master
  • 1,447 Answers
Please send me your printer show any signal
Posted on Jul 22, 2009
Canon Pixma MX300 won't print black anymore! How to fix?
I have used "refill" kits in the past and for the time and effort involved you might just try finding a local retailer that will give you credit for the empty cartridge to replace with a professionally refilled one.
The problem with refilling the same cartridge over and over again is that they will, eventually, need to be replaced. I would suggest that you
1 - Make sure there is nothing plugging the hole at the top of the cartridge to allow air in, which is needed to let the ink flow out.
2- Install another cartridge and you get the same problem, then it narrows your fix to something with the printer.
3 - If it is the printer, I were rubber gloves and use "denatured alcohol" and a rag (no not use anything with paper as it can tear and leave pieces inside causing the printer to jamb) and after removing all of the cartridges wipe down anything that I can reach inside the printer.
4 - Although you have tried the DEEP CLEAN, if the none of the above works for you, try the NOZZLE CLEAN. If you are still having a problem then either re-post the problem or doe a Google Search listing the model of the printer you have, you may find out it is a problem that others have experienced and there is no solution.
Good Luck
Apr 06, 2013 | Canon PIXMA MX300 All-in-One Printer
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
Ran out of black ink. replaced cartridge. now
If it ran dry before you replaced it then you need to do a deep clean of the head. This can be done under the maintenance tab of printer properties. If that doesn't get it working then physically remove the print head and clean it with a water moistened cotton bud (make sure you use a separate cotton bud for each ink nozzle). Running a cartridge completely dry can (and often does) damage the print head (overheats due to lack of cooling provided by the ink flow).
Oct 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
