Question about Danby DPAC8020 Air Conditioner
Why No Water in Tank?
We were just given an Everstar MCA08CR that has no issue history. It was used prior to 2009 but has been stored for about 9 months. It cools effectively without any scary noises or error messages...but no there's no water in the tank even after several hours of operation. No sign of water leaking or anywhere else.
After several hours of searching online, I've found several other people in the same situation but no explanations, solutions, dire warnings, etc.
thanks in advance!
  • online143 Jul 23, 2009
    after some mild trepidation, i decided to let it run while keeping a fairly constant eye on things. compressor kicked on and in a very short time very sweet cool air began flowing. for the next three hours, i powered down on the hour, checked the tank and found nothing. so...i left it running and about 7 hours later, i heard it beeping, the red light indicating a full tank was on and it switched from cool to fan. the tank was full so i emptied it and it is now filling about every 6 hours or so.
    thanks for your advice!
  • 22 Answers
Sounds like the compressor is not coming on. Without physically looking at it it's hard to say what is causing it. One way you can test if the compressor is working or not is to measure your room air and them the air blowing out of the unit and you should have a temp difference of about 10 - 15 degrees. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
Is it worth fixing an everstar wine cooler hdbc361d
Everstar Beverage Wine Cooler HDBC36ID not cooling
Ouch ... prior fixya thread on this model paints a pretty bad reliability picture...
Feb 15, 2018 | Furniture
Manual for everstar 095-CR-BB6
Water tank slides in from the side,and filter is behind the vent ( intake).
Jul 27, 2014 | Everstar Portable Air Conditioner Everstar
How do I fix Pegaso Trail 2009 cuts out when stopped or turning slowly?
Hi Anonymous, the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. Gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty fuel pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2009 Aprilia Pegaso 650 Trail
May 19, 2014 | 2009 Aprilia Pegaso 650 Trail
Vapor recovery
I came across this service bulletin that you will find helpful- I do believe the VCF is above the fuel tank; but if you call any diy auto parts store like NAPA, AutoZone, Pep Boys, etc.or even the parts department at Dodge, for pricing, they'll tell you exactly where it is located and they may even print out the schematic for you. Best wishes on your project. BTW, did you're "check engine" light go on? Did you get an OBD-II fault reading? Or fail an emissions test? Just curious for my own knowledge.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 14-001-09, DATED
APRIL 15, 2009, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A
COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT: Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly MODELS: 2004 -2008 (CS) Pacifica
2009 (DS) Ram Truck (1500)
2007 - 2009 (DH) Ram Truck (1500/2500 Pick Up)
2004 - 2009 (DR) Ram Truck (1500 / 2500 Pick Up)
2005 - 2009 (HB) Durango
2007 - 2009 (HG) Aspen
2005 - 2009 (ND) Dakota
2009 (JC) Journey
2007 - 2009 (JK) Wrangler
2007 - 2009 (J1) Sebring (China CKD)
2007 - 2009 (JS) Sebring/Sebring Convertible/Avenger
2006 - 2009 (K1) Cherokee (CKD)
2007 - 2009 (KA) Nitro
2008 - 2009 (KK) Liberty
2008 - 2009 (KK) Cherokee (International Markets)
2005 - 2007 (KJ) Liberty
2005 - 2007 (KJ) Cherokee (International Markets)
2005 - 2009 (LE) 300C/300C Touring (International Markets)
2005 - 2009 (LX) 300/Magnum/Charger
2007 (L2) 300 (China)
2008 - 2009 (LC) Challenger
2004 - 2009 (PT) Chrysler PT Cruiser NUMBER: 14-001-09 REV. A GROUP: Fuel DATE: September 1, 2009 2007 (R2) Caravan/Voyager (CKD)
2005 - 2007 (RG) Chrysler Voyager (International Markets)
2003 - 2007 (RS) Town & Country/Caravan/Voyager
2008 - 2009 (RT) Town & Country/Grand Caravan
2008 - 2009 (RT) Town & Country/Grand Voyager (International
Markets)
2005 - 2006 (TJ) Wrangler
2005 - 2009 (WH) Grand Cherokee (International Markets)
2005 - 2009 (WK) Grand Cherokee
2006 - 2009 (XH) Commander (International Markets)
2006 - 2009 (XK) Commander NOTE: This bulletin applies to all vehicles equipped with a gasoline engine.
DISCUSSION:
Customer may report that the vehicle is hard to fill with fuel or that the fuel pump nozzle
shuts off repeatedly while trying to fill vehicle.
This customer complaint can occur due to a number of different causes. The fuel tank is
the least likely cause of this condition. The following Diagnostic procedure can be used to
diagnose the issues.
DIAGNOSIS:
1. Is the vehicle a LX/LE/LC/L2?
a. Yes >> proceed to Step #2
b. No >> proceed to Step #4
2. Idle the vehicle 60 to 90 seconds upon stopping.
3. Does tank refill properly?
a. No >> proceed to Step #4
b. Yes >> Inform the customer to idle the vehicle for 60 to 90 seconds upon stopping if
vehicle was driven aggressively. This is due to the fact that on the LX/LE/LC/L2 the
fuel tank is a unique saddle tank design and needs 30 to 60 seconds while the
engine is running to level the fuel in both half's of the fuel tank. Allowing the vehicle
to idle for this amount of time will let the fuel pump transfer fuel to the left side tank,
opening the control valve and allowing normal fuel filling.
4. Disconnect the vapor recirculation tube at the fuel tank.
5. Attempt to refill fuel tank.
6. Does tank refill properly?
a. Yes >> Proceed to Step #7
b. No>> Proceed to Step #11.
7. Reconnect the vapor recirculation tube at the fuel tank.
8. Disconnect the other end of the vapor recirculation tube at the fuel filler tube.
9. Attempt to refill fuel tank.
10. Does tank refill properly?
a. Yes >> Replace fuel filler tube.
b. No >> Replace the vapor recirculation tube.
11. Disconnect the control valve to EVAP canister tube at the fuel tank.
14-001-09 REV. A -2-
12. Reconnect the vapor recirculation tube at the fuel tank.
13. Does tank refill properly?
a. No >> Replace Fuel Tank.
b. Yes >> Proceed to Step #14.
14. Reconnect the control valve to EVAP canister tube at the fuel tank.
15. Disconnect the control valve to EVAP canister tube at the EVAP canister.
16. Attempt to refill fuel tank.
17. Does tank refill properly?
a. Yes >> Blockage is in the EVAP Canister, or ESIM, or Clean air hose (ESIM vent
hose), or filter. Diagnose appropriately.
b. No >> Replace the control valve to EVAP canister tube.
POLICY:
Information Only
-3- 14-001-09 REV. A
Nov 26, 2013 | Dodge Ram 1500 Cars & Trucks
Howto change a key cylinder for a chevy cobalt
There is a TSB on this issues if your having ignition lock issues.
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | View All Bulletins | Document ID: 2325129
#09-02-35-005: Ignition Key Difficult to Remove, Ignition Key Binds or Sticks in Cylinder (Replace Ignition Cylinder) - (Aug 10, 2009)
Subject: Ignition Key Difficult to Remove, Ignition Key Binds or Sticks in Cylinder (Replace Ignition Cylinder)
Models: 2008-2009 Cadillac CTS (Built Prior to VIN Breakpoint 90163371)
2005-2009 Chevrolet Cobalt (Built Prior to April 14, 2009)
2006-2009 Chevrolet HHR (Built Prior to April 14, 2009)
2007-2009 Chevrolet Equinox (Built Prior to July 2008)
2005-2006 Pontiac Pursuit (Canada Only)
2006-2009 Pontiac Solstice (Built Prior to April 14, 2009)
2007-2009 Pontiac G5 (Built Prior to April 14, 2009), Torrent (Built Prior to July 2008)
Attention: This bulletin only applies to vehicle equipped with automatic transmission.
Aug 05, 2010 | 2005 Chevrolet Cobalt
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
Portable a/c - water drains out the bottom not into drain tank
where are you located,i'm in wisconsin and do A/C repair,and is it warrantied yet???
Jul 28, 2009 | Whirlwind FH-778 Air Conditioner
Don't know how much water to use
Do not put any water in the unit, the water that is in the unit drawer or bucket that is attached to the hose is a byproduct of the air conditioning process.
It transfers heat to cold and in the process produces condensation = Water.
May 30, 2009 | Everstar Portable Heater/Fan
Danby DPAC8020 Air Conditioner Logo
175 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
