Question about Grilling
I bought a new tank for EASM5500 - will it work without fascia attached?
Didn't get one with the new tank.
    Top Expert:
  • Grilling Master
  • 50,326 Answers
Put the old one back on . was not to be removed anyway .
Posted on Jan 24, 2017
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    Does one need to go inside the garage if one is fixing the fascia and soffit to repair guttering?
    Not necessarily. If the fascia board is loose, it will be easy to remove it and inspect the rafters it attaches to. If the ends of the rafters are rotten, blocking can be attached to the ends in order to have something solid to nail your fascia board onto. Make sure the fascia is solidly attached and flush for best appearance. A drip edge should be attached to prevent water from getting in behind the fascia board.
    Feb 22, 2015 | Cars & Trucks
    How do I replace my rear bumper on my 04 pacifica
    1. Open liftgate.
    133387935 Fig. 12
    1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
    2. Hoist and support vehicle with safety stands, as necessary.
    133387936 Fig. 13
    1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
    2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
    3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
    4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
    5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
    6. Place fascia on a clean surface.
    133387937 Fig. 14
    1. Remove park assist sensors, if necessary (Fig. 14).
    133387938 Fig. 15
    1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
    2. Using a trim stick release locking tabs and separate the upper and lower fascia.
    133387939 Fig. 16
    133387940 Fig. 17
    1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
    2. Remove molding from fascia.
    INSTALLATION
    1. Place bright chrome molding in position on the upper fascia.
    Jan 06, 2012 | 2004 Chrysler Pacifica
    What are the best gutter guards?
    Easy Flow Gutter Guards are the only gutter guard in the world that can be attached to an existing 5k or 6k gutter system (This is the continuous aluminum gutter system most used in America today) without compromising the integrity of the roof. Easy Flow Gutter Guards attach under the flashing on the fascia boards, protecting the fascia from all contact with rain or other forms of moisture.
    Jul 11, 2011 | Thule Artificial Rain Gutter
    I am looking for a diagram of the bumper assembly for a 2004 Chrysler town & country.
    Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
    1. Release hood latch and open hood.
    2. Remove the headlamp assemblies.
    3. Hoist vehicle and support with safety stands.
    4. Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
    5. Remove front wheels.
    6. Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
    Fig. 1 133387737
    Fig. 2 133387738
    1. Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
    2. Disconnect fog lamp wire connectors, if necessary.
    3. Lower vehicle.
    4. Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
    5. Remove bumper fascia from vehicle.
    INSTALLATION
    1. Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
    2. Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
    4. Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
    5. Install front wheelhouse splash shields fasteners.
    6. Install front wheels.
    7. Connect fog lamp wire connectors, if necessary.
    8. Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
    9. Lower the vehicle.
    10. Install the headlamp assemblies.
    Jan 02, 2011 | Chrysler Town & Country Cars & Trucks
    How do I replace dashboard heater light? The glowing lights that indicate direction of air flow.
    Heater light bulb, and all other bulbs for the air conditioning buttons, are on the same mini panel, and attached to the back of the radio front fascia. To dismount this fascia, you need 1) To pry out (no screws) the clock 2) Unscrew the one screw that holds the top of the fascia (screw is hidden behind clock) 3) Unscrew the two screws at the bottom of the fascia 4) Disconnect all connectors from the back of the fascia 5) Look for the burnt minibulb.
    You could replace the bulb without disconnecting, but the cables are short, and the possibilities of marring your dashboard are high.
    Jun 19, 2010 | 1999 Honda Accord
    How do you remove the air filter box on a 2001
    REMOVAL
    Access Rubber Grommet
    Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
    Fastener Locations
    Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
    Remove Push In Fasteners
    Remove the push pins attaching the fascia to the upper radiator closure panel.
    Headlamp Jack screws
    Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
    Roll Fascia Forward
    Roll fascia forward to clear way for headlamp housing removal.
    Disconnect wire connector from back of lamp socket(s) and/or bulbs.
    Remove Headlamp Housing
    INSTALLATION
    CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
    Place headlamp housing into position.
    Connect wire connector to lamp socket(s)
    Verify headlamp and signal lamp operation.
    Install jackscrews to attach headlamp housing to crossmember.
    Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
    Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
    Install nut on fascia stud through the splash shield access hole.
    Verify headlamp operation and alignment
    Nov 03, 2009 | 2001 Chrysler 300M
    How do you replace headlamp bulbs on 1999 chrysler 300
    You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
    Tell me if this works for you?
    HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
    REMOVAL
    2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
    3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
    4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
    5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
    6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
    7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
    8. Remove headlamp housing Remove Headlamp Housing
    INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
    1. Place headlamp housing into position.
    2. Connect wire connector to lamp socket(s) and/or bulbs.
    3. Verify headlamp and signal lamp operation.
    4. Install jackscrews to attach headlamp housing to crossmember.
    5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
    6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
    7. Install nut on fascia stud through the splash shield access hole.
    8. Verify headlamp operation and alignment
    Mar 27, 2009 | 1999 Chrysler 300M
    I need to install a kenwood cd player into my 2001 ford explorer step by step
    goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
    Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
    Insert wiring harness into the stock wiring
    attach fascia in regards to its packaged instructions.
    Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
    Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
    Insert stereo into new cage and voila nice new stereo.
    Nov 27, 2008 | Kenwood Car Audio & Video
    Grilling Logo
    323 people viewed this question
    Top Grilling Experts
    Paul Carew
    Gary Kenady
    Gary Kenady
    Dan Webster
    Dan Webster
    Are you a Grilling Expert? Answer questions, earn points and help others
