Routers
Problem for Routers
Generic problem for all Routers
My wirless laptop is not picking up my dyn...
By marienegron1 on Jul 22, 2009
My wirless laptop is not picking up my dynex rounter ip address but it is connected. Why
Comments:
Jul 22, 2009
- How do you copy n paste in DOS? So i can get you the info I can just type what it says: Microsoft Windows XP version 5.1 C:\Documents and Settings\Compaq\Ipconfig Windows Ip Configuration Ethernet adapter Local Area Connection: Media Disconnected Connedtion-Specific DNS Suffix: Blank Ip Address:192.168.0.1 Subnet Mask: 255.255.255.0 Default Gateway: Blank
Jul 22, 2009
- I have a Dynex Rounter connected to my modem working with my pc and my internet connection is okay there. I have a compaq laptop trying to use the wireless connection and it was working fine the other day and all of a sudden stopped cause we had a internet connection down. I have reconfig the router and im up but now i can connect okay on my laptop i just cannot connect to the internet, its not picking up the correct ip address.
Clarification Request
Posted by Douglessd on Jul 23, 2009
Firstly to copy form a command prompt right click on the title bar of the dos window and from the drop down menu choose Edit and Mark. Then you can drag your mouse over the text in the window to select it. Once you have the text you want selected you press Enter and this puts the text in the clip board. I think it will loose any formatting when you paste it here but hopefully we can still read it. If you plug an ethernet cable from your laptop to your router does it work ok? If not you probably have a DHCP problem. If it works with the cable connected then you have a problem with your wireless connection.
Posted by Douglessd on Jul 22, 2009
Please open up a command prompt. Click on start -> run and type cmd Type the follwoing command and press enter. (Without quotes) "ipconfig /all > c:\output.txt" This will create a file at the top of your c: drive named output.txt with the current tcp/ip configuration of your network card(s). Copy the contents of this file and paste it here and we may be able to see a problem. It sounds to me like you have a DHCP problem but the output will tell us more.
Solution #1
posted on Jul 22, 2009
Somewhat Helpful)
sitehr
Rank: Wiz
Rating: 82%, 70 votes
check security issues and give it your router DNS in ip setting
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
Hello! I can't connect my Xbox 360 into LIVE because the MTU always fail, Where do I change the... (More)
Answer
Trying to access netopia 3347 router from my home to moitor dvr cam system
Answer
I am trying to get my IP camera to work
Answer
How to set 3com 3CRWDR101A75 router standard to g.dmt explicitly?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
