Question about Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven
Hi there:
I have the appliance above and the lower oven unit door is locked. It failed to release after it was set to clean by the caterers..we have tried setting it to clean and off again and switched off the power and nothing seems to help..except for hopefully - you!
Any ideas greatly welcomed.
  • 2 more comments
  • Yellow Dog Mar 22, 2008
    I've got almost exactly the same problem but here's the difference. The oven door is open but won't shut because the "lock" has jutted out from the frame so the door doesn't close. The "key" is flashing on the screen and I can't get it to stop flashing so the lock mechanism will retract and the door will close. Suggestions???
  • Anonymous Aug 31, 2008
    I have the Gaggenau EB 194-610 convection, electric double oven. About a year ago it started locking, when I had food cooking in it, and would not open. We tried turning the temp off, switching modes, and turning off the circuit breaker. Nothing works. I have ruined several dishes, including a birthday cake. We have had a circiut board replaced and it has occurred twice since then. The repair company won't take responsibility and neither will Gaggenau. Their resolution is to offer me a replacement at the price of $3700 plus installation and the cost of renovating the cabinets, since the new ovens are larger. I have had GE ovens that lasted twice as long with no problems. I am disgusted with Gaggenau and would not buy threi products again. These ovens were about 7 yrs old when the problem began and they have not had hard use. The repair company wnats to replace both circuit boards and the lacth mechanism at the tune of $900. Any suggestions?
  • Anonymous Jan 02, 2009
    I have the same problem except that mine is the top oven.
  • brooksey May 11, 2010
    my partner thought he was he-man and tried lifting our oven that was being moved at the time by its door, you guessed it, the door has now come off as he would not be patient and weight for his friend to help carry it.
    please help, it is not broke but we cannot figure out how it goes back on.
    or who wqould we contact and how much would this cost as i want to sell it now on ebay as i have a new one ordered.
    kind regards
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Posted on Dec 19, 2007
After using self cleaning ,the door of the oven will not unlock
Yes Virginia... that is DESIGNED to <not> work that way.
The oven remains locked SAFETY REASONS... The temperatures reached during the cleaning process can damage surrounding finishes... easily burn you and ruin the appliance knobs.
It is best to PRECISELY follow the manufactures instructions...
Failing that... it is a great idea not to even change the clean SETTINGS until ALL the fans & blowers have completely shut down.
When EVERYTHING is completely cool... you reconfigure the oven for regular use... and the {cleaning} latch will release,
Hope that is <at least> informative... (pretty sure it wasn't helpful).
Dec 07, 2015 | Ovens
Whirlpool 8053294 door locked
My name is Peter. I am a retired field service appliance technician.
This is a common problem. In the upper back of your range you have a small motor which can fail and not rotate to unlock the door.
You need to pull your unit out to get behind it. Unplug your unit. Remove the top back cover and disconnect the motor. The rotate the oven door latch shaft to open the door.
Go into the following website. Input your model number (on the left) and you will get diagrams and part numbers for the repair.
Fixing an Oven that got Stuck with the Door Locked After Self Clean Water Filters Lawn Garden Appliance Parts
Jun 12, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
How to unlock the door
Hello pham, thank you for your post! Was the unit previously set on the self clean cycle? If so, the oven door will remain locked until the oven temperature has cooled down to a safe level. Try pressing the CLEAR/OFF key for approximately 15 seconds to see if it overrides the controls. If that does not working, disconnect power to the range for about 30 seconds and then turn the range on. Then I suggest setting the time of day and press the CLEAR/OFF key once again.
If the instructions above do not solve the problem, then your appliance could possibly be experiencing a communication problem with the EOC (electronic oven control), a potential wiring failure, or a faulty door lock assembly. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Aug 27, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Macmarkus :)
Sep 07, 2011 | Ovens
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
try to press and hold the clear off key for three to five may need to remove the back panel and remove the door lock mechanism in order to release the lock try unplugginf the unit for a couple of minutes as well
Jun 22, 2010 | Frigidaire FEB27S5A Electric Single Oven
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Gaggenau EB 270/271 Electric Single Oven Logo
1,024 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
